Spyderco Gardening Knife
- SpyderEdgeForever
Has there been an attempt to make a Spyderco knife specific for gardening, or work with plants such as farming? I would say it could have a blade that would be suited for pruning and grafting and similiar chores. There must be a market for this sort of thing because I have seen other knife makers produce pruning and grafting knives. What do you say?
Re: Spyderco Gardening Knife
Spyderco hawkbills fill this role 110%. Serrated for pruning and such, PE for grafting.
- SpyderEdgeForever
Very true, Evil. A gardener infact told me the hawbill is better than straight blades designed for pruning, like the straight-bladed gardener from Victorinox, he prefers the Spyderco hawbills, both Tasman Salt, Harpy, and Byrd Hawbill.
Yep. So many gardening cuts are pull cuts and you pretty much never run into a situation where you're making a "cutting board" style cut, so hawkbills don't really suffer from their drawbacks when used for gardening. The fine point also allows easy access into tight places. I think if anything, the perfect gardening knife might be something like the Dyad, but with a standard blade on one end and a SE hawkbill on the other. That way you'd have all your bases covered.
- 3rdGenRigger
Tasman PE/SE and Spyderhawk PE/SE.
All Glory To The Hypno-Toad
---> Branden
---> Branden
I'm not much of a gardener but I did my fall pruning with my Farid K-2, (I had just got it and figured why not?!). It worked great and I will use it for this and similar tasks in the future.
- RadioactiveSpyder
Vegetation in my backyard has been no match for my S110V lightweight Manix 2! A large hawkbill gardening tool in FRN would be a great lineup to the outdoor tool roster for sure.
IG: the_irradiator
IG: the_irradiator
SE Yellow Tasman is great. Wife uses a Byrd rescue a bit, she mostly sticks to secateurs though. The pairing knife is pretty good for more delicate work requiring precision.
- The Deacon
Much as I love my Spydercos, if there's pruning to be done, I'll reach for a pair of pruning shears. As for budding and grafting, I'd probably reach for either my Krein reground jigged bone Kiwi, or a Kiwi 4. Others might consider the Des Horn or Gayle Bradley Air, as well as the Kiwi 4.
+1 Use the right tool for the job.The Deacon wrote:Much as I love my Spydercos, if there's pruning to be done, I'll reach for a pair of pruning shears...
Here's my favorite gardening knife ... http://www.leevalley.com/en/garden/Page ... at=2,51810" target="_blank ... and I don't need another.
Gordon
Sometimes I use my Manix2 XL, but I usually will grab a Silky saw for pruning, especially branches over 1/2". I like the Accel 210 the best, you can cut a 1/4" twig or a 4" branch with equal ease... Those teeth are sharp! If it's mostly smaller stuff, I use a pair of bypass pruning shears...
Or sometimes a nice, sharp machete! Or a chain saw(for bigger stuff). It all depends on what I'm pruning.
Use the right tool for the job. Yeah!
SE Tasman - Pruning, root separation, general utility, twine, harvest
CE millile - Pruning, root seperation, cutting pots open, cutting open bags, twine, rope, harvest
For grafting I keep a seperate blade, PE Delica FFG, VG10 is a horticultural steel that IIRC was developed specifically for use in greenhouses. The only reason I keep the seperate knife for grafting is to ensure disease/bacteria is not introduced to the graft or to at least limit that.
The first two I would consider all around knives, the third a specific purpose knife. Not sure if there are any better "gardening" knives around.
It’s been a few years so I’d be curious to see what everyone is using these days for a gardening knife. Pondering buying something for the wife as she was asking about it.
Rich
Rich
Do not wait. The time will never be 'just right'. Start where you stand, and work whatever tools you may have at your command and better tools will be found as you go along. -Napoleon Hill
- cabfrank
If you can still find a Spyderhawk Sprint Run, I think that would be perfect. It's orange, so hard to lose, and H1, so impossible to rust. You can just rinse the dirt out and be good to go. If not, a yellow Tasman Salt would be great too, just a little smaller.
- Cambertree
The Tasman Salt SE and Pacific Salt SE are the two knives I use most in the garden.
Other knives get a run, but those two are what I always return to.
Other knives which I like to use in the garden:
Gayle Bradley 1
SE Dragonfly Salt
Becker BK9
A. Wright & Sons Lambsfoot slipjoint.
Victorinox Soldier
And I’m looking forward to trying out my new Waterway in the garden, when Spring and Summer get here.
And of course, the Silky saws are beyond compare. I use the 240mm Gomboy.
Gayle Bradley 1
SE Dragonfly Salt
Becker BK9
Victorinox Soldier
Now if we can just convince Eric & Sal to make a Japanese style gardening knife like the real thing - http://www.nisaku.co.jp/njc/garden/knife.html.
- legOFwhat?
+1cabfrank wrote: ↑Mon Aug 05, 2019 6:23 pmIf you can still find a Spyderhawk Sprint Run, I think that would be perfect. It's orange, so hard to lose, and H1, so impossible to rust. You can just rinse the dirt out and be good to go. If not, a yellow Tasman Salt would be great too, just a little smaller.
If I'm in the yard that knife is in my pocket. I've even thought about taping it to a pole just to snatch some out of reach twigs. Recently bent the the tip up pruning some ivy and jabbed it into landscaping stones. Few minutes with the sharpmaker and its ready for action.
Dont have any grafting experience though.
-Larry
MNOSD #0049
MNOSD #0049
Spyderhawk sprint run for the win! That thing is perfect for gardening work.
A hawkbill seems like it would be really good. I'd also guess k390 would be a very good steel choice despite needing constant cleaning to prevent corrosion. Great edge retention and and strength, with formidable toughness as well if you hit something unexpected. I'm sure SE H1 is good too.
