There is nothing magical about a "factory" edge. In fact a lot of people are of the opinion the factory edge will not perform as well as an edge that has been reprofiled and sharpened because of reasons we can discuss later. Also, the factory edge is at a higher angle than what the steels can hold an edge with most of the time IMO.
Lots of guys here have great advice. Cliff's opinions and advice is usually accurate I've found. I have to say I have learned a lot from his posts in the past 6-12 months.
I've learned so much from the guys here it's amazing. Also, from people on other forums, emails and on the phone. All of this has resulted in the technique I use now. It is simpler and easier to learn than anything I've done in the past. Also, and possibly more important is I know why I do everything I do. My motions are not what has developed over time based on little or no advice or teaching. In as effort to pay back for all the help I've received her and other places I made videos of what I'm doing now. I posted them yesterday in this thread:
http://www.spyderco.com/forums/showthre ... -technique. This is a simple, easy to learn technique that works. I also know why I do everything I do. Check it out if you want. By posting these videos I hope to accomplish two things. The first is to help otheres. Especially the guys just getting started. The other thing is I'd like to get opinions on what I'm doing now (good or bad). I'm still learning.
Glad you are making progress with your edge. The thing about the portion of the edge at the handle being inconsistant. I believe this is normally caused because when the stone is at that portion of the blade the steel RIGHT AT THE START OF THE CHOIL is not straight. I normally create what is known as a "sharpening notch" there. By doing this the edge remains straight and doesn't cause the edge to "raise" off the side of the stone at the corner edge of the stone. This has been discussed in detail here and all info can be found. Or ask in this thread if you don't understand the "sharpening notch". searching on the forum isn't the best.
Good luck.
Jack
