Philo Beddoe wrote:
IMO the 600lb gorilla in the room has to be the coming Maxamet Mule...
I doubt it, won't be much if any performance difference between it and the A11 class steels,
could actually be less performance due to the very high alloy content depending on the actual knife...
It remains to be seen what it will actually do and interesting if the edge stability would be stable enough for knives that are ground thin so they can be useful.
From Carpenters website:
http://cartech.ides.com/datasheet.aspx?i=101&E=84
Micro-Melt Maxamet alloy may be considered for many types of tooling applications where either conventional high speed steels or cemented carbides are currently being used. Possible applications could include those where high speed steel is currently being used and an upgrade is desired but the switch to carbide is unattractive due to cost, tooling manufacture, toughness, or machine rigidity concerns; or applications where carbide is currently being used but is not cost-effective due to limited production runs or toughness/breakage problems.
Possible applications for this alloy could include:
Hobs
Punches
Form tools
Taps
End mills
Milling cutters
Thread roll dies
Indexable inserts
Broaches
Wear Resistance
The wear resistance of Micro-Melt Maxamet alloy is better than that of conventional powder metal high speed steel grades and is equivalent to AISI A11 cold work powder metal tool steel.
