Pivot Washers
fredswartz
Pivot Washers
Post by fredswartz »
Some of the finest Spydercos that I have owned have had Mylar or some other plastic looking pivot washers. They all worked great for me. Other knives have had bronze pivot washers which seem more substantial. There is a reason why some knives get synthetic washers and others get metal. What is the reason ?
Buendia518
Post by Buendia518 »
I don't know the answer but I agree that my Junior with plastic washers is smooth and serviceable.
Random Dan
Post by Random Dan »
And then there's the Caly, which has no washers yet is still extremely smooth.
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -George Washington
RanCoWeAla
Post by RanCoWeAla »
I don't think those are necessary and you get closer tolerances without them. The only place you are going to have any wear in the pivot area of a knife is where the end of the tang rides against the spring . That's why old slip joints sometimes have very weak back springs. And if you don't have a back spring you won't have that.
Post by The Deacon »
Mostly PR. Spyderco used a lot more "plastic" washers until a bunch of self-proclaimed forum experts declared phosphor bronze to be infinitely superior.
araneae
Post by araneae »
I could care less what they are made of as long as they work.
-Nick
Last in: N5 Magnacut
gijoe945
Post by gijoe945 »
I am far from an expert. Know just enough to be dangerous. When I worked in a power plant, we used a Teflon, peel ply brass and phosphor bronze washers on some equipment, namely sootblowers. The Teflon seemed to outlast and was slightly better in these applications.
JNewell
Post by JNewell »
The Teflon and nylatron washers are definitely smoother, at least initially. It's pretty hard to envision situations where the Teflon and nylatron washers would not be as durable as bronze, in real life use. Having said that, I definitely understand the preference for metal... :o
xceptnl
Post by xceptnl »
The Deacon wrote:Mostly PR. Spyderco used a lot more "plastic" washers until a bunch of self-proclaimed forum experts declared phosphor bronze to be infinitely superior.
Paul, do you recall when you noticed this PR motivated transition by Spyderco to more phosphor bronze?
*Landon*
RanCoWeAla
I just don't think they are necessary. A lot of knife makers use them just to make the knife open easier and smoother. However when you open up the pivot end of the knife and mount the blade on a smaller platform there is no way it cannot contribute to side to side blade play. As for the Caly 3.5 you couldn't use washers and get the kind of seamless finish you have along the back of the knife. Personally I try to stay away from them because I think they are responsible for a lot of the blade play you hear discussed.
xceptnl wrote:Paul, do you recall when you noticed this PR motivated transition by Spyderco to more phosphor bronze?
Think the push for PB washer, or rather the negativity toward the various "plastic" ones, started in 2005 and the move to them sometime thereafter, say 2006.
Blerv
Post by Blerv »
I can only assume it's based on the maker's own preferences and constraints of a particular design.
All of my "plastic" bushing knives are insanely smooth so I certainly won't be complaining :) .
dbcad
Post by dbcad »
With a slow speed, low load application like a blade pivot any number of polymers would work well. The FRN on my washerless knives works quite well also ;)
Charlie
JNewell
Post by JNewell »
Blerv wrote:I can only assume it's based on the maker's own preferences and constraints of a particular design.
A lot of custom makers use something other than PB because of the smoother action. Really, when did anyone wear out a "plastic" bushing???
gull wing
Post by gull wing »
I have several knives with "plastic" washers, they are just "OK" for my part. I've seen metal bits imbedded in the washers after a while, don't know how serious this is.
What cooks my noodle though, is a VERY thick plastic washer on one side and a VERY thin PB washer on the other side. :eek:
SCARAMOUCHE! :bug-red-white
Officer Gigglez
Location: Originally out of Arizona, currently live in Missouri.
Post by Officer Gigglez »
In my experience they both work. The bronze doesn't seem to work anymore than the plastic. I really don't care what is in there, so long as they function.
-Tenacious, Combo edge
-Tasman Salt, PE
-Persistence Blue, PE
-Pacific Salt, Black, PE
-Delica 4, Emerson Grey
-DiAlex Junior
-Byrd SS Crossbill, PE
-Endura 4 Emerson Grey
-Byrd Meadowlark 2 FRN, PE
-Resilience
gull wing wrote:I have several knives with "plastic" washers, they are just "OK" for my part. I've seen metal bits imbedded in the washers after a while, don't know how serious this is.
Is it the different materials, the different thicknesses, or that specific combination that annoys you?
JNewell
Post by JNewell »
The Deacon wrote:Is it the different materials, the different thicknesses, or that specific combination that annoys you?
And, joining in the quiz, what knife did you encounter that mixed washers? It doesn't seem like a problem physically, though it might annoy those of us who are right-brained. :)
JNewell
Post by JNewell »
Officer Gigglez wrote:In my experience they both work. The bronze doesn't seem to work anymore than the plastic. I really don't care what is in there, so long as they function.
Yes, I basically agree. And I was thinking of washerless knives like the Caly3 today - they work fine. I suppose there may be more friction as it opens, due to the greater surface contact, but I never noticed it with mine. The other issue, that we have seen many complaints about over the years, is the rub marks on the blade where it contacts the liners, but that is truly an esthetic issue, not a functional issue.
