Blade polishing with tooth paste...
Blerv
Post by Blerv »
I pulled out my Caly3 Superblue sprint and noticed that when I put it away the blade wasn't completely clean. Almost like I cut open a sandwich bag and didnt wipe it off (sufficiently). A small amount of liquid + 2 months of sitting had allowed a bit of faint rust to form on the blade, hardly anything horrible looking but definitely triggering the OCD hobbyist panic :eek: .
Anyways, I should have Fitz polish but since it was very minor I figured a very mild abrasive and a bit of elbow-grease might work. I cleaned some superficial corrosion off a stainless necklace flashlight with Colgate tooth paste and a brush after about a year of EDC use. With a cloth shop rag and a few minutes of scrubbing it's all but gone.
Next time you grab a knife that looks a bit dingy or has a few specs of corrosion, give it a shot. It's sure food safe edible and bound to make your knife smell like spearmint. :D
xceptnl
Post by xceptnl »
Blerv wrote:I pulled out my Caly3 Superblue sprint and noticed that when I put it away the blade wasn't completely clean. Almost like I cut open a sandwich bag and didnt wipe it off (sufficiently). A small amount of liquid + 2 months of sitting had allowed a bit of faint rust to form on the blade, hardly anything horrible looking but definitely triggering the OCD hobbyist panic :eek: .
To add to your excellent suggestion Blerv, I have found that the liquid Barkeeper's Friend works great at removing tarnish or corrosion from stainless knives. It will also remove the patina from some carbon steels.
*Landon*
Blerv
Post by Blerv »
xceptnl wrote:To add to your excellent suggestion Blerv, I have found that the liquid Barkeeper's Friend works great at removing tarnish or corrosion from stainless knives. It will also remove the patina from some carbon steels.
Oh cool, thanks :) .
xceptnl
Post by xceptnl »
Blerv wrote:Oh cool, thanks :) .
I do prefer Flitz though. I was actually planning to make a flitz loaded strop for polishing (not edges).
*Landon*
chuck_roxas45
Post by chuck_roxas45 »
xceptnl wrote:I do prefer Flitz though. I was actually planning to make a flitz loaded strop for polishing (not edges).
I do have a metal polish loaded strop. I use it to bring back the polish on the bevels of non stainless knives, mostly my SB caly 3.5. I find that metal polish works better than diamond paste on getting rid of unwanted patina. :)
xceptnl
Post by xceptnl »
chuck_roxas45 wrote:I do have a metal polish loaded strop. I use it to bring back the polish on the bevels of non stainless knives, mostly my SB caly 3.5. I find that metal polish works better than diamond paste on getting rid of unwanted patina. :)
Which side do you guys suggest I load? Smooth or napped side of the leather?
*Landon*
Holland
Post by Holland »
Very cool find, thanks for sharing
Officer Gigglez
Location: Originally out of Arizona, currently live in Missouri.
Post by Officer Gigglez »
Just did this on my Tenacious. Worked like a charm. No more rust. Thanks for the tip.
-Tenacious, Combo edge
-Tasman Salt, PE
-Persistence Blue, PE
-Pacific Salt, Black, PE
-Delica 4, Emerson Grey
-DiAlex Junior
-Byrd SS Crossbill, PE
-Endura 4 Emerson Grey
-Byrd Meadowlark 2 FRN, PE
-Resilience
Blerv
Post by Blerv »
Cool :) . Glad to hear!
Post by The Deacon »
Never tried it on knives, but in the distant past I've used toothpaste to restore clear plastic parts on model cars and airplanes and as a substitute for valve lapping compound on a small engine or two, so I'm sure it would work. One thing to be aware of is that many toothpastes contain whitening agents of one kind or another and at least some of those whitening agents are oxidizers. Not saying don't use it, but do be sure to thoroughly clean the knife afterward.
Pinetreebbs
Post by Pinetreebbs »
Toothpaste is good for polishing out scratches in CD and DVD disks. Test it first, not all toothpaste has the same size grit.
Two cleanser products contain a safe fine abrasive, Barkeepers Friend and BonAmi. They are great for light polishing and keeping your Sharpmaker stones clean.
Blerv
Post by Blerv »
The Deacon wrote:One thing to be aware of is that many toothpastes contain whitening agents of one kind or another and at least some of those whitening agents are oxidizers. Not saying don't use it, but do be sure to thoroughly clean the knife afterward.
Great note, Paul :) .
Yea it washes away easy enough but you certainly don't want to leave any on the blade. Chemicals aside (which are certainly questionable) trapping moisture is counter-productive to say the least.
Jimd
Post by Jimd »
Neat idea!
Referee in the Bowels of ****
Email: ST8PEN01@aol.com
Artwork For Sale
"...We few, we happy few...we band of brothers...For whoever sheds his blood with me today shall be my brother." - William Shakespeare
If you are not willing to stand behind our troops, by all means, please stand in front of them!
xceptnl
Post by xceptnl »
Update for Blerv. After getting this well loved Kiwi in the mail yeserday I studied and considered how I planned to get out the scratches in the bolsters. I attempted both a baking soda toothpaste and a whitening toothpaste with little to no results. To be fair, I also tried Flitz for about 5 minutes per bolster with only minor success. Once I broke out my Stropman strop with black and green compounds the results really came. I wasn't looking for a perfect mirror, just a more even scratch pattern. Maybe with a stronger toothpaste I would have whiter teeth and shinier knives! :D
Before:
After:
*Landon*
Holland
Post by Holland »
Nicely done Landon
Blerv
Post by Blerv »
Nice work Landon! :D
Yea, it's really just a convenient grit and gunk remover than anything. Maybe with a dremel toothpaste would work but I would rather go with the proper compound and broad slow strokes.
w3tnz
Post by w3tnz »
xceptnl wrote: Image
Nice score! Jelly! :) Polished up real nice, still planning to try a stonewash?
xceptnl
Post by xceptnl »
w3tnz wrote:Nice score! Jelly! :) Polished up real nice, still planning to try a stonewash?
Not for now. I do need to reprofile the blade because of a big chip, but for now I put on a medium stone microbevel and this thing went onto the watch pocket. With some use I may still consider the stonewash later. It is surprising the difference between the slimmer all stainless and this stag model.
*Landon*
