For quite a while I've been wanting to check out this model. The Knifecenter XHP variation gave me the perfect excuse. I've wanted to check out this steel for some time as well
For a pinned linerless FRN knife the Native feels incredibly solid and stable. The Native has no discernable play in any direction, has a well centered blade and is very nicely fitted and finished all around. The action doesn't have the crispness of the Cento3 but feels solid and reassuring nonetheless. It seems to have a deep lock notch as well. to unlock it the lockbar has to be depressed fully :D The bottom choil and finger groove in the handle give a nice secure grip which combined with the lightweight make this a very controllable and comfortable blade to wield :D
The blade shape is also interesting :) A hollow grind on the edge and a swedge ground into the last 2/5ths of the spine yielding a needle like tip :eek: on the 1/8" thick blade.
It came nicely sharp but I opted to reprofile. With a hollow grind I'm always looking for the path of least resistance :eek: :D It will be fun to see how the XHP holds up under relatively light use with the lower edge angle :) The XHP took a nutty superkeen edge pretty easily :D It feels like it will be pretty easy to maintain :)
I'm very happy to have made this purchase and discovery. The Native has the feel of a low key comfortable everyday user. The Native/Urban duo will be in my pocket for a little while now. Thanks Clip for giving us a heads up on this one.
This XHP Native is a sweet feeling knife :D
First Native experience
Charlie
- Screwdriver
- Manix Guy 2
- Cheddarnut
