Page 1 of 1
How to Dull SS Pocket Clip?
Posted: Tue Jul 30, 2013 9:16 am
by MatthewSB
How would you go about dulling the shiny SS pocket clip that comes on a satin bladed Para2 or Native5?
I'm thinking about using a scotchbrite pad to rough it up a bit so it matches the luster of the blade and other parts.
Thoughts?
Posted: Tue Jul 30, 2013 9:28 am
by Evil D
You can stone wash it or acid etch it to completely remove the shine. I prefer a dull non reflective clip, and you can use ferric chloride to turn it a flat gray color. Then normal wear with give it a cool worn natural stonewash finish.
Posted: Tue Jul 30, 2013 9:33 am
by MatthewSB
Evil D wrote:You can stone wash it or acid etch it to completely remove the shine. I prefer a dull non reflective clip, and you can use ferric chloride to turn it a flat gray color. Then normal wear with give it a cool worn natural stonewash finish.
What would make it closest to the finish of the S30V satin blade?
Posted: Tue Jul 30, 2013 10:42 am
by Evil D
MatthewSB wrote:What would make it closest to the finish of the S30V satin blade?
Probably just get a rough scotcgbrite pad and rub it up and down in one direction. The finish on the blade is from grinding it so you just need to put a scratch pattern in the clip that's similar.
Posted: Tue Jul 30, 2013 11:08 am
by MatthewSB
Thanks so much.
Will post a pic when done...
Posted: Mon Aug 05, 2013 7:02 am
by MatthewSB
Scotchbrite pad worked great! Just went from side to side so it matched the pattern of the blade when closed.
Para2 next to a stock Yojimbo 2. You can see it's not nearly as reflective as the original polish.
Posted: Mon Aug 05, 2013 8:17 am
by xceptnl
Beautiful finish and a great modification that anyone can do. I would repost this on the "show your mods" thread as well.
Posted: Mon Aug 05, 2013 8:38 am
by ourgon
My PM2
sand paper 1000 + hot oil wash
Posted: Mon Aug 05, 2013 11:01 am
by Evil D
ourgon wrote:My PM2
I've heard of this but never tried it? Looks awesome.
Posted: Mon Aug 05, 2013 8:06 pm
by Orion's Belt
ourgon wrote:My PM2
Any info on how that is done? Looks great.
Posted: Mon Aug 05, 2013 8:45 pm
by edc solutions
Yes, what exactly is the hot oil wash other than awesome looking??
Posted: Tue Aug 06, 2013 8:10 am
by Coulro
Also interested in the hot oil finish, it looks great! How durable is the finish?
Posted: Tue Aug 06, 2013 9:33 am
by Evil D
If I'm not mistaken you just heat it up and dip it in oil.
