Gator Skin texture pattern for the Endura
- BOOMER52
I came up with a new texture (Gator Skin) that I wanted to play with... and decided to go with a bolstered look. Playing a bit with CAD I landed on a single bolster design and then went further and created a double bolster. After a day or two viewing the PREVIEW CAD images I decided to go with the double bolster BUT a reverse curve at the bolster junctions... it just suited the lines of the knife better.
I had the olive drab G10 but just a small amount of black G10 on hand and figured that the best way to go about this project was to do inlays. Here's some pics of the process...
This is the CAD PREVIEW of the original version...
I then reversed the bolster junction curve...
The idea was to use inlayed black G10 as I had very little on hand...
The inlayed G10 would machine like this...
AND... so it did...
This is the result compared against the CAD PREVIEW image...
Fun project...!
AND... so it did...
Fun project...!
- kennethsime
Woa, I thought this was just a CAD layout! Nice work! Did this Endura start life as a G-10? If not, did you mill out the inside of the scales to nest the liners like factory or build it linerless?
- BOOMER52
This is an Endura 4 FRN and I do double sided machining for the nested liner pockets.kennethsime wrote:Woa, I thought this was just a CAD layout! Nice work! Did this Endura start life as a G-10? If not, did you mill out the inside of the scales to nest the liners like factory or build it linerless?
The scales are awesome! The Gator pattern is sweet to look at and looks very nice in green and black. The drawing and real knife look exactly the same! Great job!
It looks like this patterns gives a lot of gip. How do they feel in hand?
Current EDC: Techno, Squeak, Southard Flipper, Caly 3.5
New Arrivals: Chap3, Domino, Sage 3
2014 Wishlist: Yo2 CF, Deviant Friction, Tatanka, Tusk, Firefly
Oldies Wishlist: Delica CF PE, Civilian CF PE
How much do you charge :)
Do you have a CNC setup at home that does this? Homebrew design with router or similar, or actual mill with CNC capability?
Chris
Chris
- CarbonFiberNut
Anybody who builds a device out of 80/20 is OK by me
◊ Manix 2 XL ◊ Manix 2 lightweight blue ◊ Caly 3 carbon fiber ◊ Caly 3 damascus / CF ◊ Lum Chinese Nishijin ◊ Sage 1 ◊ Superleaf
◊ Dragonfly FRN serrated ◊ Endura Gen 1 ◊ Rescue Gen 1 ◊ Endura 4 FFG ◊ Delica 4 half serrated ◊ Mule Team ◊ Spin ◊ Bushcraft UK
◊ S110V Forum Native 5 ◊ Black Nishijin Cricket
[SIGPIC][/SIGPIC]
Top 5 most wanted: Domino, Dice, CF Para-2, CF Cricket. Seeing a theme here?
[SIGPIC][/SIGPIC]
Brother you have some wicked talent...GREAT JOB!!!BOOMER52 wrote:I came up with a new texture (Gator Skin) that I wanted to play with... and decided to go with a bolstered look. Playing a bit with CAD I landed on a single bolster design and then went further and created a double bolster. After a day or two viewing the PREVIEW CAD images I decided to go with the double bolster BUT a reverse curve at the bolster junctions... it just suited the lines of the knife better.
AND... so it did...
Fun project...!
