Will steel knives ever be replaced with hand held short distance lasers?
- Buck Knives I Like
:confused: And if that day were to come.. what would be your response.
- The Deacon
They may be an alternative at some point in the future. However, since obsidian blades are still considered better than steel for some delicate surgical applications, I doubt anything will ever completely replace steel for knife blades.
- Gunslinger
The problem, in a knife application isn't just power, it's containment. You'd need some sort of field to both stop and shape the beam.Gunslinger wrote: This is my 125mW Viper laser pointer. You can see the smoke. You can buy up to 1.4W handheld Laser pointers. and Module Lasers that go much higher. With a focus lense you can make them more powerful and short range.
I think we're a ways off from that.
But in that vein, has anyone seen the blue light knives on Defiance? Very cool!
Ken
玉鋼
- Gunslinger
They make focus lenses that cause the laser to come to a focus point where the beam is smallest, this is where the burning or cutting power is at the highest. then the beam spreads like a flashlight and is basically just light.
Now the focus lense doesn't focus the beam as dramatic as the pic. It focuses down to where you have a few inches of high burning laser before it spreads.
[SIGPIC][/SIGPIC]
- Gunslinger
I should edit when I said "We aren't to far from it". I definitely think we have a while before lasers will replace knives, but I think we will see cutting lasers used in more portable fashion soon. I don't think it will ever be in a lightsaber form like everyone wants or thinks of when the word laser is used.kbuzbee wrote:The problem, in a knife application isn't just power, it's containment. You'd need some sort of field to both stop and shape the beam.
Ken
[SIGPIC][/SIGPIC]
- Gunslinger
- Lord vader
- The Deacon
One potential limitation is that many items we cut with knives are either flammable to some degree, or easily damaged by heat.
- Gunslinger
- Fred Sanford
I don't think so. Reason being is this: We (the USA) decided we needed a pen that would write in space and Fisher came up with the Fisher Space Pen. The Soviets decided that they could use a pencil. LOL. Sometimes the most complicated product isn't the best. I'm happy with a sharp "scalpel like" knife. :)
Call me when they develop a laser that can spread peanut butter on the apple after cutting it.
- Stuart Ackerman
Knives do not need batteries...just skill...
My website...
http://ackermancustomknives.com/
Facebook...
https://www.facebook.com/ackermancustomknives/
Facebook...
- chuck_roxas45
So make burn proof paper. :DGunslinger wrote:Oh yeah, Good point. This makes laser paper cut test very difficult. :D
