Black Blade Para 2 Stain
paychekk
Post by paychekk »
Today at work I carved the peel on a orange with my para 2 and to my surprise I could not clean the citrus acid from the peel. It stained the black coating on the blade. Any one else have this problem. What can I use to clean the blade without damaging the black coating. :eek:
DRKBC
Post by DRKBC »
That is a drag, it may have eaten into the coating a bit, have you tried just wiping it down with wd40?
Holland
Post by Holland »
ya true wd40 or goof-off
BAL
Post by BAL »
I have had a Military DLC for a couple years and have done quite a bit of cutting, (never an orange
though) and teh black looks the same as when I bought it. I don't think that you can damage it,
unless you take a course paper to it. I just wash mine with soapy water and rub it pretty hard.
I have had marks on it that I thought was a scratch, but it ended up cleaning off. The best of luck
to you.
Knifeaddict
Post by Knifeaddict »
I sharpened a pencil with my black blade military and had a **** of a time getting all that **** lead ( Iknow its not really lead) off the blade!!!!
senorsquare
Post by senorsquare »
Holland wrote:ya true wd40 or goof-off
Yeah, goof-off is good for cleaning gunk off of things.
What you're seeing is a moistened area on the dlc. If you rub an orange all over the surface it'll all darken and look the same and eventually dry out.
Fresh Eddie Fresh
Post by Fresh Eddie Fresh »
I have a black Manix, and some parts of the blade are darker than others... I actually think it came that way. It just reminds me that I have to use it more. :)
phillipsted
Post by phillipsted »
I don't think the DLC coating is damaged, either. Evil is right - what you are seeing is oil or moisture on the surface of the coating. A quick wipe with alcohol, WD-40, mineral oil, windex, or plain ole' water will probably take care of it and make it look like new.
I haven't found anything short of a tough abrasive that will damage the DLC...
TedP
