There is a torx screw on both sides, which one adjusts the tension on the blade for opening??? I can take the one right out on the clip side and it doesn't seem to do anything??
Is there a trick or procedure for adjusting the tension?
Thanks.
Paramilitary blade tension question
That's not really true with most of the Spyderco knives using this design (P2, M2). This isn't a Sebenza, either in design or in manufacturing tolerances. If you are not getting tension adjusted with the pivot screws, tighten or loosen the stop pin screws, which will also affect how easily the blade rotates on the pivot.
+1JNewell wrote:That's not really true with most of the Spyderco knives using this design (P2, M2). This isn't a Sebenza, either in design or in manufacturing tolerances. If you are not getting tension adjusted with the pivot screws, tighten or loosen the stop pin screws, which will also affect how easily the blade rotates on the pivot.
Despite the claims of the bushing pivot system... there is enough variance knife to knife (I've bought six so I have seen the variance personally) that shows that tightening the pivot (on some knives) does indeed affect tensioning (2 of mine it has great affect upon). On some tweaking the standoffs can also have a great affect, etc. Again... lots of actual variance when it comes to these knives. I wish they were all immune to blade tensioning changes when tightening the pivot screw, but it's just not the case.
Apparently, arachnophobia is not a condition from which I suffer.... :spyder:
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them." (oops!)
--Thomas Jefferson
PLEASE VISIT MY BLOG >>>1all's Pub<<<
--Thomas Jefferson
You could always buy a Sebenza...oh, wait, they're a little more expensive! :eek: :D :spyder:
jon1all wrote:+1
definitely try this out, ive had success playing with the stop pin in the past. also rotating it can help sometimesJNewell wrote:That's not really true with most of the Spyderco knives using this design (P2, M2). This isn't a Sebenza, either in design or in manufacturing tolerances. If you are not getting tension adjusted with the pivot screws, tighten or loosen the stop pin screws, which will also affect how easily the blade rotates on the pivot.
