Yup after flicking it open for a while, I'm noticing some side to side blade play on my Ti Military. I heard that's to be expected with Ti Frame Locks. is this the truth? If not, is it worth doing anything about it? I don't have the tools to tighten it otherwise I'd just tighten the pivot a little.
Ordered a Gorilla Grip torx key thing. Anyone have tips on keeping the blade centering good? Also, it seems to me that the Timi has only one adjustable pivot screw. The other side seems to be just a doing piece of metal. Why is this?
Having a screw on the other side of this type of pivot isn't necessary. As to the centering you just have to look while you are tightening the pivot, very simple.
We would rather be the knife in your pocket, because is "works" better, than the knife in your showcase, because it "looks" better.
Blerv is just trying not to let slip the *real* secret to a play-free blade. Welding. A properly welded pivot will exhibit no play without physically destroying the knife. PROTIP: Take your hands OFF of the blade before applying welding heat to it. This is the #1 mistake made by folks reporting to hospitals with disfiguring knife pivot welding injuries.
kbrouwer wrote:Ordered a Gorilla Grip torx key thing. Anyone have tips on keeping the blade centering good? Also, it seems to me that the Timi has only one adjustable pivot screw. The other side seems to be just a doing piece of metal. Why is this?
There are two parts to the pivot design. You have a male part, the screw, and a female part, the other side of the pivot that is domed.
The female part has a flat area to make sure it can only go into the knife in a certain way. This is vital and many people end up forcing it in. Big mistake.
Here you can see the male and female parts on the military and CRK Umnumzaan
At the end, you should just tighten the male screw a bit, judge centering by the eye and do not take it apart.
"If you wish to live and thrive, let the spider run alive" "the perfect knife is the one in your hand, you should just learn how to use it." If you don't have anything good to say, then don't say anything at all
The knife does not have to be centered to work, a nice thing to have, but not necessarily a must.
Some knives can not be centered without bladeplay, just the way it is.
My :spyder: Endura 4 FFG Plain, Black in VG-10 had been my faithful EDC companion since 9/26/2012
