Anyone use stag scale material before?
phillipsted
Postby phillipsted » Mon Sep 24, 2012 10:56 am
I've made lots of knife scales over the years in a wide range of materials. But I've never worked with stag before. Before I pull the trigger and order a set to try out on the new MT15, I thought I would check with folks to see what the "ins-and outs" were of working with the material. (I'm referring to real stag here, not plastic resin-based stuff or jigged bone scales)
How do they work? Are they brittle or chippy? Do they carve well?
Any tips would be appreciated.
TedP
gull wing
Postby gull wing » Mon Sep 24, 2012 4:01 pm
No, but let us know how it turns out(pictures).
I do know horn is tricky and bone(cow shank) is a bit easier to work with.
Good luck.
SCARAMOUCHE! :spyder:
Stuart Ackerman
Postby Stuart Ackerman » Mon Sep 24, 2012 4:10 pm
If you are talking Sambar, then slow speeds to prevent burning...as the stag holds heat...
Any other stag is semi-hollow, and does not burn as quickly...but slow speeds are still recomended...
Bone is much easier to use...but it is not stag...
2cha
Postby 2cha » Tue Sep 25, 2012 5:46 pm
zackerty wrote:If you are talking Sambar, then slow speeds to prevent burning...as the stag holds heat...
Axis stag is also not hollow. Other thing to remember is that it warps a little when heat is unevenly applied--ie, when sanding at higher speeds. (also smells like burning hair)
phillipsted
Postby phillipsted » Wed Sep 26, 2012 7:44 am
Thanks for the feedback, guys. I forgot that antler is basically one huge hair - and I really *love* the smell of burning hair in my shop. I'll keep the drill press low-and-slow, and limit myself to hand tools for flattening, shaping and contouring...
I found a nice set of Sanbar Stag scales online. Here's a shot of what I'll be working with - the seller has already done some of the prep work... I'll get to them next in the queue - right after I finish a new MT02 in Ironwood Burl. Pics to follow!
TedP
bh49
Postby bh49 » Wed Sep 26, 2012 9:28 am
phillipsted wrote: I found a nice set of Sanbar Stag scales online. Here's a shot of what I'll be working with - the seller has already done some of the prep work... I'll get to them next in the queue - right after I finish a new MT02 in Ironwood Burl. Pics to follow!
TedP
Nice stag.
Users browsing this forum: Deadboxhero, Google [Bot], Majestic-12 [Bot], niobiumcarbide, RROG, Sumdumguy and 56 guests
