Manix 2 reassembly
Manix 2 reassembly
So..... I was thinking, my M4 Manix needed a good clean and lube (you know where this is going, right..?)
Came apart easily. Everything cleaned and nice application of Nano Oil I put the spring and backspacer back on, attached the pivot and washer, reinstalled the blade, second washer, slid the second scale back into place and replaced the pivot screw and remaining two scale screws
Everything seemed to be fine but after assembly there is some side to side blade play.... When closed, the blade moves almost from one scale to the other. 1/2 open the blade feels loose on the pivot. Open, it's not bad if the lock is engaged but if I pull it back you can feel the wobble.
What did I do wrong?
Ken
Ken
玉鋼
DeathBySnooSnoo
Mine was similar when I took it apart. I found that it took some fiddling around to get the screws tightened properly in proportion to each other to get the play gone, especially the first set of backspacer screws, but both sets need to be balanced. I found that cranking them down is too tight. Snug seems to be better for the back ones at least.
Also, make sure that the liners are square. With everything loose to the point of falling apart, I like to put it pivot end down, give it a good thump on a solid and flat surface and then while pressing down securely on the other end, start tightening the backspacer screws first, then the pivot.
Seemed to help mine, hopefully it will help yours.
On the hunt for...
Maybe the ball of the lock? Look carefully IF it is there yet. The plastic support of the ball have a right side to place it in order to keep the ball locked inside. If you put the support inverted, the ball may run away without advice after 1st opening.
If you are still in troubles, please advise me in order to help you.
Cesar
Cesar
:spyder: This is my faithful everyday companion since 2010: Manix 2 Guetto Wave :spyder:
Yeah, I thought about that and it could be what's going on. The first one is easy to see when you're reassembling. You put the washer down and feed the pivot through it into the liner and insert the screw. No worries. But on the other side you are sliding the liner/scale over it into position (because they are still attached by the lanyard hole) so it's a bit blind. I assume that was what Graeme was going for with his "tap it" suggestion. To ensure the pivot is fully seated. I've done it 4-5 times now, always with about the same result (switching "first" sides in case one side was seating more easily that the other). I don't know how to look "inside" to check it though.mattman wrote:never disassembled one, so this is just a thought, but are the "shoulders" on the pivot bushing fully seated into the liner recesses?
don't know if that is easy to miss, or not...?
Ken
玉鋼
Not a wild goose chase at all. At this point any input is most welcome.mattman wrote:Remove pivot screws, pinch scales at pivot location with fingers, and jiggle the blade slightly to "seat" the pivot bushing?
What you describe is pretty much how it goes back together. With the one side fully seated (which is easy to see) you position the other side until it kinda of snaps into place. It does, as Graeme mentioned, take a bit of "fiddling" but eventually it drops in. I have tried loosening the pivot screws after assembly, but nothing shifts further at that point.
Ken
玉鋼
I have disassembled mine one time to clean and oil, and start a thread about fixed lanyard hole. Hummm, lets think what may happen... The scales look rock solid or are also wobble too? Did you tried to move it inside/outside and there is movement or not? The lanyard hole have larger corners than the body... are you sure that it is very well fixed to the right place (it is also over the g10 scales too)? If not, the space in scales can be justified by this concern, and obviously the blade move. I didn't removed the lanyard hole and let liners and scales together to clean. Try to double check it and return to us to tell how you are doing. Sure someone here will help and I will keep in touch.
Can't see that. The pivot is cut to accept the washers on it's ends. If they are misaligned it won't go back together at all (which is kinda why you have to reassemble it in the order I described.mattman wrote:well, the only other thing I can think of is washer mis-alignment?
The scales are solid and there does not appear to be any space between the scales/liner/back spacer.cesar wrote:The scales look rock solid or are also wobble too?
There is slight movement at the tang (side to side), as if the pivot is too long (but it isn't). It almost has to be something is preventing the pivot from seating all the way (or preventing the pivot screws from tightening further) but I can't seem to get them any deeper. Regardless of which side I start with, that side appears flush (pivot to washer to liner) The gap has to be coming from the second side not seating correctly (just logicing through it)cesar wrote:Did you tried to move it inside/outside and there is movement or not?
I didn't remove the lanyard hole either. It appears intact/in position with no space showing on the near post....cesar wrote:The lanyard hole have larger corners than the body...
Ken
玉鋼
- jackknifeh
When you put the first pivot screw in to hole the post in place snug it up but don't tighten. Put all the screws in on that side of the knife but don't tighten, just snug. When it is all together try tightening the pivot screws first. Since there are two I snug one, then the other and test blade play and smoothness. If there is blade play I barely turn one pivot screw. If play remains I barely turn the other one. Point is to keep the tightness of the pivot screws approx. the same. Then try tightening the other screws. The ones that go into the front of the backbar can effect tension but I don't think the back screw has any effect. But, since the problem lies in the pivot I'd try working on that to start with.
This is a suggestions that I have never tried because I've never had a problem with blade play when assembling a Manix2. My only "problem" area is getting the bearing/housing in place and holding it there until the second liner is in place holding it. The key here is to put the bearing assy in first, then pull them back and drop the blade in. I tried the blade first and never did get it to work so I re-watched the video I had and saw my problem.
Don't know if working on the pivot first will make a difference or not. Good luck.
Jack
Jack
I tried the pivot first, Jack, exactly as you describe. Later, on Graeme's recommendation, I tried the spacer screws first. No difference either way.jackknifeh wrote:When you put the first pivot screw in to hole the post in place snug it up but don't tighten. Put all the screws in on that side of the knife but don't tighten, just snug. When it is all together try tightening the pivot screws first. Since there are two I snug one, then the other and test blade play and smoothness. If there is blade play I barely turn one pivot screw. If play remains I barely turn the other one. Point is to keep the tightness of the pivot screws approx. the same. Then try tightening the other screws. The ones that go into the front of the backbar can effect tension but I don't think the back screw has any effect. But, since the problem lies in the pivot I'd try working on that to start with.
You're right, that ball bearing assembly can be a little son of a gun. Trick I learned today was to leave the rear back spacer screw engaged and pivot it over the ball bearing assembly to hold it in place while you're working on it (one time I launched the bearing clear across the living room. That was exciting
At this point, I'm down with witchcraftcesar wrote:witchcraft... could you post some detailed pics?
Nope, it's smooth and quiet.cesar wrote:Any scratch noise when open/close?
Ken
玉鋼
Fred Sanford
Take it apart again. Put it back together. This time flip the bushing that goes in the blade. Only tighten all the screws about 50%.
This has happened to me in the past and I found that for some reason the CBL needed to be able to put itself where it needed to be. I opened and closed the knife slowly a few times with the screws loosened and then I tightened the pivot almost all the way down. Then I tested to see if the play was gone. It wasn't so I sort of moved the handles up and down and sorta just played with them and then I heard the CBL sort of "click" into wherever it needed to be. After that I tightened everything down and all was good.
When I say "moved the handles up and down" what I mean is this: If you hold the knife with the back of the handle facing you and the blade tip facing away from you with the edge down and the knife open you will be able to hold a handle with each hand. You will be looking down on the spine of the knife. Like this you can grab each handle scale/liner and tweak them up and down and back and forth a little. Do it with the blade open and also with the blade closed and see if you can get a "click" and then see if the play goes away. :)
Let us know.
Let us know.
