Is the hole of the paramilitary2 larger than the military's ?
xia63
Post by xia63 »
i found the trademark round hole
of paramilitary2 (C81CFP2/C81GPBN2/C81GPBL2)is larger than the military's (C36CFM390P/C36CFBGP), and it is beyond 14mm, why?
[ATTACH]19874[/ATTACH]
thanks
rycen
Post by rycen »
They are the same size.
We would rather be the knife in your pocket, because is "works" better, than the knife in your showcase, because it "looks" better.
xia63
Post by xia63 »
another pic
xia63
Post by xia63 »
another pic
[ATTACH]19877[/ATTACH]
Post by The Deacon »
Assuming you're correct, why would that be a problem, or an indication of anything other than the obvious - that the blades are completely different and therefore were manufactured using different computer settings on the machine (or machines) that cut them? While significantly bigger is always better, Spyderhole size is not really a critical dimension, a couple thousandths one way or the other isn't going to make any difference in the way a thumb fits into it. Most would not even notice it.
xia63
Post by xia63 »
yeah, thanks Paul.
I am not a real Spyderco's collector, I got paramilitary 2 recenly, but i have never touch the paramilitary before. I thought the construction and size of paramilitary 2 are so fit to me, of cause the other key point is for so many powder steel's sake. The hole is not a problem for me, I just want to know more detail information of paramilitary 2 even compare to military. I guess that is one of the improve of Spyderco from military. :D haha
your colletions are so great,and your website is so helpful for us.
thanks again Paul.
enduraguy
Post by enduraguy »
Hole on my Para 2 is slightly larger than on my Millie for sure.
Benny90
Post by Benny90 »
On the Spyderco website they are both listed as 14mm (.563 in.). I've seen some errors in other spots though so..
http://www.spyderco.com/catalog/details.php?product=472
http://www.spyderco.com/catalog/details.php?product=19
If it's right, the older Milie's probably had a smaller hole than the newer ones.
Ken44
Post by Ken44 »
When I got my first Para 2 that is one of the first things i noticed. I started to measure it just to see(not that it matters), but just assumed it was an optical illusion since it was on a smaller knife.
enduraguy
Post by enduraguy »
I dunno. My Millie is a newer run. I can lay my Para 2 blade on top of my Millie blade and it's obvious the Para 2 hole is larger. Doesn't bother me though.
God'sMyJudge
Post by God'sMyJudge »
the hole in the lionspy is humongous - much larger than any other spyderco knife i have
It's definitely larger, and even though it's only a small amount my thumb sure knows the difference. Blame it on the times...holes seem to be getting bigger on the newer versions of knives. I'd expect the Military 2 to be as big as the Para 2.
darkstar29
Post by darkstar29 »
Evil D wrote: -snip-
Not to hijack the thread, but has a Millie2 been announced?
Sorry if it's common knowledge, but I've been away from the forums for awhile.
Also. Yeah, the P2 hole is noticeably larger than the Millie.
I walk away slow tonight,
and cut through the air
with a curse, like a knife.
darkstar29 wrote:Not to hijack the thread, but has a Millie2 been announced?
It has been in the works for about a decade i think but nothing official. There's talk of it coming with the Stop Lock but who knows.
darkstar29
Excellent! For a camp folder, nothing beats a Millie.. Except, maybe a GB. Even then it's a close one. IMO.
Thanks, Evil D :)
Now lets get crackin on that Millie2, Spydercrew ;)
