Plain vs ce vs se
- razorsharp
I use all 3
I've used all 3 edge variants on several different occasions. My current EDC knives are my Caly Jr ZDP-189 PE model and my H-1 Spyderhawk SE ( G-10 Harpy is currently on the missing persons list )
MY third EDC I've been using the **** out of is my PE Temp 1 model fixed blade. That VG-10 super blade has more than earned my respect and I do hope that they will bring that blade back in H-1.
I always have at least one PE and one Spyderedged blade on me daily. I do like my Spyderedged blade to be a Hawkbill model for many reasons but I do carry my sacred C-60 Massad Ayoob Spyderedged version from time to time.
Probably my favorite CE Spyder to carry and I've carried it some here recently is my C-46 Lum Tanto folder. It's the best CE Spyder I used in quite a while.
I find uses for all 3 edge variants and I don't look for that to change anytime soon.
701 Profiles are the remedy
Razorsharp just get a set of Spyderco 701 Profiles and you'll be able to sharpen any of Spyderco's great edges. It blows me away that Spyderco is going to discontinue this great toolrazorsharp wrote:PE, I dont have an SE sharpener and more knives come in PE
Please people don't let the sharpening issue dissuade you from owning and using any of Spyderco's great edges.
True they're worthless dull but have you ever tried to sharpen serrations on a rock or in the field?Blerv wrote:Yes Evil but people aren't made of cardboard and paracord. We also have nerves :) .
Joking aside you do have a point: It's HARD to beat a screaming sharp PE knife. A dull one however is next to worthless.
I find most of my regular EDC is PE cause that is the configuration they come in. Each edge has its time and place. I will usually carry a SE or CE along with a PE. If I am carrying more than one Knife.
The CE gets a bad wrap but they are extremely useful and not all that hard to sharpen. My CE Millie and CE Stretch are just about perfect for household chores. If they would only put out a CE Para 2.....
Yes, thank you for making my point. Scalpels with PE are used because they make a nice clean cut. A serrated blade may make a more ragged uneven cut and cause more nerve damage.Evil D wrote:There's a reason scalpels don't have serrations.
Actually scapels are not use that much anymore. Many surgeries are done with an electronic scapel. http://www.digikey.com/Web%20Export/Sup ... directed=1
Maybe in the near future we will be talking here on BF about our electronic knives.
We would not let our people have ideas why would we let them have guns? Josef Stalin
Well actually they do, they're just arranged in a way so that each cut they make scoops out the wood they cut. If you look close enough at the chain they're just hundreds of little plain edge knives. A better way to. look at it is to say they're little chisels or even tiny wood planes that chisel/shave with each pass. Either way I wouldn't call them serrations..357 mag wrote:and there is a reason chainsaws don't have straight blades.
