I confess - I batoned with my Salt1
Posted: Fri Jan 06, 2012 8:25 am
I was at the beach over the holidays visiting my family. Since I was on travel, I didn't pack a large contingent of knives - just my PE Salt1 and my H-1 Dragonfly.
As it turns out, the weather was nice enough for us to go down to the beach and build a nice bonfire one evening. When the family unloaded the wood for the fire, I noticed immediately that we didn't have adequate kindling and tinder to get the blaze started. So while the kids dug the fire pit, I sorted through the pile and picked out a bunch of old cedar siding shingles to make into firestarting material. (these are thicker than roofing shingles and don't taper as much)
I started by shaving off a big pile of tinder, which the PE Salt 1 chewed up easily. One of the older gentlemen with us noted that my "funny looking small knife" certainly made short work of the tinder. He asked me what it was, and we had a good time talking about the merits of H-1, the Spyderhole, etc.
Next, I had to create some kindling. My only option was to split the shingles lengthwise into 1/4" or 1/2" strips. I tried doing this job by hand, but I just couldn't get enough hand pressure to split the shingles effectively.
So, I decided to go against all my better judgement - and violate one of my primary beliefs (use the right tool for the job) - and baton the Salt1 through the shingles. I know...I know... I've ranted against mis-use of knives in previous threads... But I really didn't have any choice - aside from a shovel and a hot-dog fork, this was the only tool I had at my disposal.
To start off, I got a short piece of 1x3 to work as the baton and used a small log as the base. I started each of the kindling strips by hand, then used the baton to drive the Salt1 down the grain of the wood, splitting off the strips. I was careful to not torque the FRN scales - just using enough support with my fingers to keep the knife parallel to the ground. I worked this way for about 15 minutes, chewing up a dozen shingles and making an impressive pile of kindling.
My Scout son immediately got the "teepee" set up and used his firesteel to get the blaze going. In short order we had a roaring fire, hot dogs, s'mores, and a good time.
The Salt 1 came through like a champ. As you might guess, the soft H-1 got quite a bit of scratching on the blade's surface. But the edge (which was polished out to a mirror finish at 30 degrees) came through with little wear, still able to push cut newsprint across almost the entire edge (except for a couple of small dings caused by knots). It exhibits NO blade play in any direction. But, I got sand in the pivot, of course. :) I'll post some pictures later this evening - I haven't cleaned it up yet.
Overall, I'm really glad I had the Salt1 with me. I regret having to "abuse" the knife - but it performed like a champ. Thanks, Spyderco!
TedP
TedP
