Sal Id love some input on this. Would you like to see this for evaluation?.
I know what to fix on it, I dont want to void it though and dont want to worry about paying $30 to get it there and back
![frown :(](./images/smilies/frowning-face.png)
My caly was gritty, but that was grit and not a burr, wash you caly in hot soapy water and dry thuroughly and lube , and do the process quickly LOL :D :pKardinalSyn wrote:Same issue on my SB Caly3.5. Plus where the blade is held by the pivot (tang part as mentioned above), I can see a scrape line right on the centre of the metal. Its a tad annoying when the opening is not fully smooth but I can live with it. I am not going to take mine apart to sand the inner part of the lock bar down or anything as I am not very good at putting things back together.
Washing Up, I can. I did so twice already with no improvement. Hot soapy water, then with running tap water and oiled it. No luck. When I look inside the handles, I can see that the back of the lock back mechanism is not finished as well as I would like for a knife of this kind. there is one section near the tang that is sort of a darkish brown color as against the chrome color of the other parts.razorsharp wrote:My caly was gritty, but that was grit and not a burr, wash you caly in hot soapy water and dry thuroughly and lube , and do the process quickly LOL :D :p
hmmmKardinalSyn wrote:Washing Up, I can. I did so twice already with no improvement. Hot soapy water, then with running tap water and oiled it. No luck. When I look inside the handles, I can see that the back of the lock back mechanism is not finished as well as I would like for a knife of this kind. there is one section near the tang that is sort of a darkish brown color as against the chrome color of the other parts.
No issues mate. It's not a major issue for me.razorsharp wrote:hmmm. Maybe sal will chime in with input. I also emailed him with this thread
Yeh, i cleaned out the lube a few hrs ago to try work out the burrRockcrawler wrote:This is interesting... possibly a buzzed out comment but... I think maybe that oiling doesn't really help the issue as it prolongs the life of the burr from smoothing out... My Yo2 was a bit gritty at first but seems to be smoothing out without cleaning or oiling just use... Lock fully depressed its smooth as ice...
I can send you my one for you to investigate if you like though I have pulled it apart to investigate. I have come to the conclusion that it isn't the lockbar but is the round tang. After polishing the contact part of the lockbar, it still wasnt smooth, I stropped the tang but its the same.sal wrote:Hi Razorsharp,
We have had a few peoplpe comment onthe "grittiness", but we don't have any with the problem to investigate. We've mentioned it to the maker and they said they would watch for it.
The one that I carry has been fine since new and the two that I have in the box are also fine.
I've yet to have one that I could inspect myself.
