Gut Hook
Gut Hook
Can you sharpen a gut hook with the Sharpmaker?
I have a the gut hook made by buck. Its sharpened on both sides and is squared off. The SM rods won't fit in there right. I've been using a small block of wood with sand paper.
For the rounded gut hooks, a steel works the best but you may be able to get a SM rod in there. A dowel rod and sand paper will work good too.
- The Deacon
Dowel and sandpaper, round Lansky "Mini Dog-Bone" Crock Stick, or Spyderco's Round Ceramic File or Ceramic File Slip Stone.
DMT conical sharpening tool is great
I have a conical ceramic sharpening tool I got from DMT over 3 years ago and it's been a dream to use to sharpen my 2 gut hooks. DMT also has the same tool in diamond as well.
There are several diamond impregnated and ceramic tools out there which will do a great job of sharpening most gut hooks. But again not all gut hooks are the same.
The one on the original Spyderco Impala model was one of the better ones I've ever seen.
- ChapmanPreferred
You can sharpen a gut hook with a Sharpmaker rod, if you use the fingernail clipper sharpening technique from the Sharpmaker video. :)
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
Work EDC List
[SIGPIC][/SIGPIC]
