Dropped my Gayle Bradley...Ouch...
I dropped my GB at work the other day from chest high. It hit the concrete floor on the blades edge and has about 1/2" of small chips going on along the edge. What should I do? I'm so sad this is truely one of my favorite knives.
- Teddy Thompson
It may depend to some degree on the size of the chips. If the knife looks like it has a Spyder edge they may charge you $20. Otherwise they'll probably just consider it a complimentary sharpening and ask for $5 for return postage. Only way to be sure is to contact them.
Support your right to keep and arm bears!
A decent pic would help. It would depend a lot on your being comfortable with sharpening. Sharpening has been one of the steepest curves I've climbed since I started buying and using these knives. I believe CPM M4 is not too difficult. It is a tool steel.
Sending to :spyder: is a good option as well. Would like to see a pic though. I've had hurt knives myself :)
Charlie
