Page 1 of 2
Do you close your Manix with one hand or two?
Posted: Sun Apr 03, 2011 3:14 pm
by crispeto
I figured out how to close it with one hand but I still don't seem as confident as when I close my Sage or Tenacious. How do you guys mostly do it?
Posted: Sun Apr 03, 2011 3:24 pm
by MCM
(1)
Posted: Sun Apr 03, 2011 3:30 pm
by The Mentaculous
I use one hand, and just let it swing shut. I have done it many times so I automatically get my fingers out of the way--it helps for me to grip the clip with my 3 fingers that aren't gripping the lock release. I used to be kind of scared of the momentum of the blade and how it swings shut so suddenly, so I would just release it for a split second, let it fall halfway, then let go and let the ball bearing re-engage. Then I would close it the rest of the way manually in a very controlled manor. It's a good compromise if you want to close it one-handed, but still are a bit apprehensive.
Posted: Sun Apr 03, 2011 3:44 pm
by SQSAR
One handed.
Posted: Sun Apr 03, 2011 4:09 pm
by Googz
+1 Locks like the one on the Manix are my favorite because you can one hand close without touching the blade.
Posted: Sun Apr 03, 2011 4:13 pm
by spyderHS08
One handed, you can pull the ball lock back with your thumb on one side and middle finger on the other and push the blade shut with your index finger. Or you can do as others have said and pull the lock back with your thumb and middle finger and swing the blade shut. :cool:
Posted: Sun Apr 03, 2011 4:15 pm
by crispeto
Cool, I feel better now. I didn't know if it was normal to just let it fall close like that. I actually use my pointer finger with my thumb. Seems to work.
Posted: Sun Apr 03, 2011 4:47 pm
by Evil D
One hand. Just pinch the handle between your palm and your pinky/ring/middle finger and use your thumb and index finger on the lock and let it drop down shut. If it's too tight you might need to swing it shut some.
Posted: Sun Apr 03, 2011 5:08 pm
by JNewell
One hand. Not a fan of uncontrolled drop closings. I use thumb and middle finger to release the ball and the index finger to close the blade.
Posted: Sun Apr 03, 2011 6:10 pm
by angusW
One hand here. Use the index finger and thumb. I've never thought of using the middle finger. Something is wrong with me. I tried it a couple of times and can't do it :o
Posted: Sun Apr 03, 2011 6:13 pm
by Pinetreebbs
One handed... carefully.
Posted: Sun Apr 03, 2011 7:13 pm
by DeathBySnooSnoo
The Mentaculous wrote:I use one hand, and just let it swing shut. I have done it many times so I automatically get my fingers out of the way--it helps for me to grip the clip with my 3 fingers that aren't gripping the lock release.
+1 thats how I do it too. Happens automatically now...never even nicked a finger.
Posted: Sun Apr 03, 2011 8:46 pm
by jackknifeh
I've only handled one Manix and within a couple of minutes got comfortable closing it one handed. I have another knife that the lock release is exactly like the Manix (different lock) but you only need to use my thumb and closing it is very fast. Needing the other finger is a tiny tiny bit inconvenient but easily gotten used to. I have to think that needing to pull both buttons at once is part of the design of the ball bearing lock because if it could be closed with just the thumb Spyderco would have designed it that way (I'm assuming).
Jack
Posted: Sun Apr 03, 2011 9:36 pm
by DeathBySnooSnoo
I think too that if it were easy to do with one hand...more fingers would have been cut off by now ;) That Manix blade is SO smooth and free and weighs enough that if you got your fingers caught in there I bet you'd have some serious bleeding going on...
Posted: Mon Apr 04, 2011 12:30 pm
by rodloos
Yep, my Manix 2 bit me within 1.5 seconds of me taking it out of the box :) . I'd read of questions about the difficulty of closing it, so I pulled on the lock release... while the blade was pointing up and my other fingers were gripping the handle, the blade swung down and got me :) .
I can't open/close my manixes (manii?) as absent-mindedly as I can my back-lock spyderco's, but I do use one hand - usually pointing the blade down, release the lock, then rotate my hand so the handle is actually coming down to the blade. Otherwise I don't like the blade swinging freely shut if I'm not actually looking at the blade.
Posted: Mon Apr 04, 2011 12:42 pm
by DeathBySnooSnoo
I hold it up, but since my fingers are tucked up holding the clip, I never get my fingers in the way, so I think that I can close it faster than my back locks.
Posted: Mon Apr 04, 2011 1:07 pm
by Scottie3000
One hand. I usually close the back of the blade against my leg while squeezing the release.
Posted: Mon Apr 04, 2011 2:37 pm
by Pneumothorax
One hand. Hold it horzontal, pull the CBBL back and let the blade swing down. Fingers obviously not in the way. Wish I could do it with just my thumb, but I cant - gotta use thumb and index finger.
Posted: Mon Apr 04, 2011 2:52 pm
by defenestrate
I do it one-handed, and sometimes with just the thumb, though if it is very fatigued I would have a hard time actuating the lock with said thumb.
Posted: Mon Apr 04, 2011 3:11 pm
by dsmegst
rodloos wrote:Yep, my Manix 2 bit me within 1.5 seconds of me taking it out of the box :) . I'd read of questions about the difficulty of closing it, so I pulled on the lock release... while the blade was pointing up and my other fingers were gripping the handle, the blade swung down and got me :) .
I did that with my first Manix 2 also. I was holding it straight out, pulled the release and the blade swung down and back onto my finger. :rolleyes: Dummy...
I like to tighten up my Manix 2s to where the blade barely moves by gravity alone. A small shake and it closes half way and only if I initiate movement. I can add more motion and it will close all the way but then I move my fingers out of the way before I initiate.
