C36TIP Upgraded
C36TIP Upgraded
I have been harping on this since November when I found out they were upgrading the TiMil Ril with the lockbar insert that the M4 Military had. And here it is finally. :D
Now the production version includes the lockbar insert. This will solve any pre-mature lockbar travel where you have Ti contacting steel. It also appears to be replaceable should it wear in fully or blade play developes.
This is another example of Spyderco's constant improvement philosophy. :thumbup:
-Rob
Knuckle dragger
Knuckle dragger
I have one of the ones without the new piece to it. Have had ts just shy of a year.
I use it hard, never any issues, however I am envious.
Hopefully my Fluted Millie will have it.
http://www.spydiewiki.com/
they already made the switch for the normal Ti and G10/Ti, all the fluted Ti will have it.FIMS wrote:I have one of the ones without the new piece to it. Have had ts just shy of a year.
Alexandre.
Spyderco WTC#1978
Spyderco WTC#1978
- The Deacon
A number of makers use steel inserts. A number of makers use variants on the Hinderer over travel stop. A number of makers, Lion Steel included, uses both. But Spyderco took it one step further, and combined the steel insert with an over travel stop that engages the lockbar from inside the handle, rather than from outside as the Hinderer stop does.Phrenik wrote:Was spyderco the one to come up with this idea though? Since I have seen it on lionsteels knives for a long while now, ex the SR-1 and some others I forget. Just wondering who the credit should be going to.
Credit goes to spyderco. They improved on a design and made it their own with their superior design. Just like how mr. walker gets credit for the liner lock and mr. reeve gets credit for the framelock. One is an evolution of the other and the person who makes thats change gets credit.Phrenik wrote:Was spyderco the one to come up with this idea though? Since I have seen it on lionsteels knives for a long while now, ex the SR-1 and some others I forget. Just wondering who the credit should be going to.
Simplicity is the greatest sophistication. Props to Spyderco for that design. It is always good to get two birds with one stone.The Deacon wrote:A number of makers use steel inserts. A number of makers use variants on the Hinderer over travel stop. A number of makers, Lion Steel included, uses both. But Spyderco took it one step further, and combined the steel insert with an over travel stop that engages the lockbar from inside the handle, rather than from outside as the Hinderer stop does.
- Wisehybred
- JacksonKnives
Haven't we seen photos of the fluted Ti Millie without the insert?
Maybe that was the prototype...
To be honest, I don't think I'd ever miss it if I didn't have it, but I do appreciate the quality design and engineering that went into the insert. The Millie is definitely the knife for it.
—Daniel Jackson
- The Deacon
IIRC, the fluted Ti prototype was shown at Blade last year as a concept model. If that's the case, it was built before the controversy responsible for the addition of the insert.JacksonKnives wrote:Haven't we seen photos of the fluted Ti Millie without the insert?
- chuck_roxas45
Well, wouter's fluted millie has no steel insert.
I think it's visible in this pic.
http://www.spyderco.com/forums/showpost ... ostcount=4
- chuck_roxas45
Read this link. Should get you up to speed.marlinspike wrote:Without rehashing the merits of each side, could you fill a forum-newbie in on the controversy?
http://www.spyderco.com/forums/showthre ... el+inserts
