Cleaning ceramic stones?
- jackknifeh
How do you guys clean ceramic sharpeners. I've heard comet and 3M scrub pads. I just found an item on a web site called a Super Eraser. Below is the description.
Super Eraser is made by Idahone Inc. and is especially effective for cleaning of ceramic rods. With use, a ceramic honing rod will develop a residual build up from fine metal shavings that lodge in the crevices of the rod. Just rub this on the rod to clean.
It costs $5. Does anyone know if something like this is better than comet or just another gizmo?
I just got a set of the 701 profile stones and want to keep them in good shape. So far they really work great. I should know, I've owned them almost a whole day. :) Any other cleaning suggestions are welcome also.
Thanks,
Jack
Thanks,
Jack
- jackknifeh
I forgot to mention the stones I got were factory seconds off ebay and came without a pouch. That's ok I guess because the price was good but does anyone know where to get just the pouch? I'm not trying to buy anything from anyone here just looking for sources that aren't too expensive. I would like the pouch but it's not a very big deal. I've emailed Spyderco about it. Maybe they have some on hand.
Thanks,
Jack
Thanks,
Jack
- defenestrate
- jackknifeh
ICSK wrote:I just use toothpaste to clean the ceramic rods on my Sharpmaker. It works better than soap and water and is readily available.
Toothpaste? Really? That's great because it is always around. I'm going to try it. Do you recommend floride or non-floride? Maybe extra whitening? :DCobra4246 wrote:I tried toothpaste to clean mine today. It worked great thanks for the idea
Jack
All of the products/methods mentioned work great, in addition I've also used a regular ol' pencil eraser too. However, I prefer the comet and 3M pads with some warm water...
"A man who is of sound mind is one who keeps the inner madman under lock and key."--- Paul Valery
Survive, Adapt, and Overcome...
I'm not sure that that matters. You're certainly free to experiment. It works on the basis of toothpaste being the cheapest and most readily available abrasive. Certainly much better than soap + water.jackknifeh wrote:Toothpaste? Really? That's great because it is always around. I'm going to try it. Do you recommend floride or non-floride? Maybe extra whitening? :D
Jack
Hi Jack,
Some time ago I bought a product called the magic eraser. Basically it is a rubber stone, like an eraser with abrasives in it. It works excellent, and after using it, I will not use anything else. I hope that this helps, and if You find where to get them, let Me know,as I need to buy a few More.
Good Luck,
Charlie
Good Luck,
Charlie
- jackknifeh
buddy54ck wrote:Hi Jack,
Good Luck,
Charlie
If it is a Mr. Clean product this may be it. If so I'd like to know if it is what you used and liked.
http://www.mrclean.com/en_US/magic-eraser.do
I found this product and sort of planned to get one if I get some of the other products on this site. I like to wait and get everything I want on one order to save shipping. A couple of items are on back order that I want. If this is what you remember let me know as well.
Thanks,
Jack
- jackknifeh
OOPS! Forgot to add the link to the other product I found. Sorry.jackknifeh wrote:If it is a Mr. Clean product this may be it. If so I'd like to know if it is what you used and liked.
Thanks,
Jack
http://www.chefknivestogo.com/suerccero.html
Jack
Hi Jack,
That's it (http://www.chefknivestogo.com/suerccero.html!) I guess that I'm a little hard on them, but I rub the ceramic pretty hard, and I have become obsessed with keeping the rods clean. After cleaning the rods You will actually feel an abrasive drag on the blade steel, so You know that the honing action is working well. I am a machinist and I have tried numerous other rubber stones, something used by tool makers, and they just do not work as well as this product. When You try it out, You will see what I mean, It is very obvious! I hope that this helps, and thanks for the link to the product.
May I add You to My Friends List?
Thank You,
Charlie
Thank You,
Charlie
- jackknifeh
Charlie,buddy54ck wrote:Hi Jack,
Thank You,
Charlie
Great I'll be getting one soon. Someone else suggested toothpaste and I tried it and it worked but now my toothbrush tastes like metal. :D
Jack
