presenting your
presenting your
Dudes ~
How do you present your <img src="spyder.gif" width=15 height=15 align=middle border=0>s?
1. Do you flick it open?
2. Do you do the <img src="spyder.gif" width=15 height=15 align=middle border=0> drop?
3. Use the <img src="spyder.gif" width=15 height=15 align=middle border=0> round hole with your thumb?
Sam
have bone implant will travel..
Sam
- vampyrewolf
I normally use the <img src="spyder.gif" width=15 height=15 align=middle border=0>Hole, but on occasion do a drop.
<img src=http://us.f1.yahoofs.com/users/372fcedb ... 8A88UxWudf> We all start with 10 fingers. Those with Spydies have 9 to spare, Still need a thumb. Good thing I still have 8 to spare... <img src=http://us.f1.yahoofs.com/users/372fcedb ... 8A88UxWudf>
Usually use the hole. Sometimes I drop if I need to get it open fast. I almost never flick it open. Too many potential non-knife people where I work.
Wise man say, forgiveness is divine. Remember that when your <img src="http://www.spyderco.com/forum/spyder.gif" border=0> bites you!
It really depends on which <img src="spyder.gif" width=15 height=15 align=middle border=0> I'm carrying. I flick the Military, drop the Harpy and Civilian, and use the Hole for everything else.
<img src=http://www.spyderco.com/forum/spyder.gif>Size Matters<img src=http://www.spyderco.com/forum/spyder.gif><img src=http://us.f1.yahoofs.com/users/372fcedb ... 8A88UxWudf>
- Big-Target
doing the drop means to perform the "spydie drop" or reverse drop. To do this, grab the hole firmly in thumb and forefinger, adding more fingers if you can for stability, and with a flick of the wrist, throw the knife down toward your feet. DO NOT LET GO OF THE BLADE! you're not really throwing it, but that's the motion you need. at the end, give a flick of the wrist as you abruptly start pulling the blade back up, and the handle will flick out and lock into position, positioning the knife well for the forward grips. It takes a little practice, but it's not as hard as it first sounds.
Xibalba- the infamous <img src="spyder.gif" width=15 height=15 align=middle border=0>Drop is done thusly.
Hold your knife firmly, index finger and thumb on the hole, middle finger holding the knife at the hump behind the hole.
If it is indexed correctly, you have the knife pinched with your thumb/index and have it resting slightly on your middle finger.
Now, flick your wrist downward, similar to cracking a whip. The weight of the handle and the momentum should open the blade all the way.
I myself don't much care for the drop, though I use it occaisionally. Primarily, I use the hole.
Keepin' it real...real sharp, that is.
Thumb hole, drop and flick are too hard on the wrists. <img src="sad.gif" width=15 height=15 align=middle border=0>
Linda
<img src="http://www.spyderco.com/forum/spyder.gif" border=O> Integrity is being good even if no-one else is watching <img src="http://www.spyderco.com/forum/spyder.gif" border=O>
Linda
