Why do people like tip down carry?
I simply fail to see any advantage to tip down carry, unless you're afraid the knife will open on your hand or something inside your pocket. It adds a whole new motion just to get the knife open, you have to pull it out and then shift the bottom to your palm and THEN flip it open with your thumb. Plus you can't zip tie wave tip down carry....
this all came up because I just ordered a civilian and was hoping to wave it, but then realized it's tip down carry only....now I have to find a sheath or something in order to be able to use it quickly in emergencies :rolleyes:
Nice
yablanowitz wrote:Grasp the blade by the Spyderhole, draw the knife from the pocket, flick the handle down and it's open. For me, it's faster than tip up. And yes, I have had tip up knives open in my pockets several times.
Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure... than to rank with those poor spirits who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat.
Theodore Roosevelt
Theodore Roosevelt
This says it all.
I don't see why anyone would prefer carrying tip up. I honestly don't see any advantage.yablanowitz wrote:Grasp the blade by the Spyderhole, draw the knife from the pocket, flick the handle down and it's open. For me, it's faster than tip up. And yes, I have had tip up knives open in my pockets several times.
With tip down if you are wearing a ring on your finger, you will either scratch the blade or the ring or both.
I prefer tip up, I like to get a full on grip of the knife as I pull it open and deploy the blade. I rarely drop to open.
I think it is just a matter of preference. Whether toilet paper rolls over the top or off the bottom, you will still get the same outcome.
-Brian
A distinguished lurker.
The advantage of tip-up is, you can pull and open the knife without ever pinch-gripping. Tip-down, every opening always involves a pinch grip. For any use which involves stress opening, tip-up is the way to go, as anyone who has ever thrown their knife across the room on a fast pinch-grip opening (admit it, that includes 100% of us) can attest.
The possibility of tip-up carry resulting in opening in the pocket is a very realistic concern. While I strongly favor tip-up, I only like carrying that way for knives that have a lock that provide a strong positive closing bias -- lockback being the best, something like a ball lock being not too far behind, and an integral/liner/compression lock only being acceptable if the ball-detent mechanism is really well executed.
- chuck_roxas45
I find that tip down on longer knives like the military, endura, chinook puts my thumb near the thumb hole as soon as it's out of my pocket without having to shift my grip.
Good points Joe. I would add that no matter what configuration you chose to carry, that you practice deploying it to build muscle memory. I've recently added a Shabaria to my stable, and was kind of bummed that it can only be carried tip-down. All my others are set for tip-up carry. It would be no problem to drill and tap for a tip-up carry, but I'm kind of reluctant to make that mod (for aesthetic reasons) especially since the way it rides as it came from the factory is very low and discreet. There's always a catch-22 isn't there.
- Rev. Chuck
I always carried tip up, until I got my Military, now I am getting used to tip down carry, I really don't see any disadvantage in any of the two, with tip down I use the Spyder drop, tip up I flick them open.
:spyder:~ SPYDERCO NAVIGATOR II ~ C93,~ SPYDERCO "S" BLACK ~ C109BKP, - SPYDERCO DELICA 4 FLAT GROUND FRN ~ C11F,- SPYDERCO ENDURA 4 FLAT GROUND FRN ~ C10F,- SPYDERCO ENDURA 4 FLAT GROUND FRN ~ C10F,- SPYDERCO PERSISTENCE G-10 ~ C136G,- SPYDERCO TENACIOUS ~ C122,- SPYDERCO MILITARY DIGITAL CAMOUFLAGE G-10 ~ C36GCMO.:spyder:
- Spydesense
The pocket clip on my Civilian can be moved for tip up or tip down carry... right hand only though. I usually like tip up better, so I moved the clip to carry that way. I ended up changing back to tip down... it just seems to work better. Like Joe and Chuck said, I guess it is because the knife is so long, if it is tip up, your hand is too far away from the hole when the knife is pulled out of the pocket. Therefor, you have to "inch" the knife up to be able to get thumb in hole. If it is tip down, your thumb is already close to the hole when retrieved from pocket. Kinda hard to explain, but that's my theory.
My :spyder:'s>> Fluited Titanium Millie, M390 Millie, Brad Southard, Gayle Bradley, Junior, Bushcraft UK, Translucent Blue Manix 2, G10 UKPK, Sage 1, Sage 2, Ti Damascus Delica 4, Orange FFG Endura 4, Gray FFG Endura 4,Native, Blk Dragonfly, H1 Dragonfly 2, Blue Tenacious, Tenacious, H1 Ladybug, White Ladybug, Grasshopper, Honeybee and Bug
Tip-up is SLOWER. It is. Spyderdrop or no Spyderdrop. It's also more difficult to get the knife out of the pocket.
Also, tip-DOWN is LESS SAFE. How can a knife carried tip-up open up if it's against the seam of the pocket? It can't. On the other hand, a knife carried tip-DOWN has the blade's path pointing toward the INSIDE of the pocket, so there's a chance that it can open up when your hand is on it's way up out of the pocket (don't ask how; we never understand how these freak accidents happen lol)
I think that most people believe in myths where exactly the opposite is true when it comes to tip-up/down carry.
Im not good at sharpening, even with a sharpmaker. How get your blade good can your blade with an edge pro system? - Bladeforums user
Has anyone really been far even as decided to use even go want to do look more like? - Some Online Meme
- chuck_roxas45
Well, whatever works for you...
- Leatherneck
- jabba359
Guess I'm a mess when it comes to this question. Got a Khukuri tip-up in the front right pocket, Millie tip-down in the front left, and my Ladybug clipless (of course!) in my change pocket. Since most of my knives are tip-up, I've gotten used to pulling them out and opening them that way. The tip-down always goes in the left pocket and I've gotten used to pulling them out that way on that side as well. Either way, the spine of the blade always sits against the back seam of the pocket, so no trouble with accidental openings here. Speed has never been an issue, as I have no need to have my knife out and open where a fraction of a second makes any sort of difference.
Initially, I was a big fan of tip up, but this was on smaller knives. After I started carrying a Military, I too realized that it was very fast and consistent.
Since then, I prefer my knives to be tip-down for consistency. Whatever knife I have on me is drawn and opened the same way, from the Cricket to the Resilience and everything in between. It also doesn't hurt that my favorite knives are all tip-down only.
I think Sal covered this well when he says (I'm paraphrasing), "Not good or bad, just different."
42 Spyderco fixed blades and counting...
You mean, for you. For me, a fast, *reliable* opening, tip-up is faster -- grab and thumb open with no pinch grip.THG wrote:Tip-up is SLOWER. It is. Spyderdrop or no Spyderdrop. It's also more difficult to get the knife out of the pocket.
Well, the thing about this one is, people have been talking on the internet about knives that open in the pocket and cause an injury (or almost cause one) for years. In 20 years, I'm not sure I've seen many tip-down stories, there are lots of tip-up opening stories. Unlike the speed-of-opening topic, which is subjective, I think the beyond-a-reasonable-doubt evidence is for tip-down safety. Not saying a tip-down opening has never happened, but it appears to be a really rare beast.Also, tip-DOWN is LESS SAFE. How can a knife carried tip-up open up if it's against the seam of the pocket? It can't. On the other hand, a knife carried tip-DOWN has the blade's path pointing toward the INSIDE of the pocket, so there's a chance that it can open up when your hand is on it's way up out of the pocket (don't ask how; we never understand how these freak accidents happen lol)
- The Mentaculous
