Anyone see this news thread at KC?
I'm not sure but I bet one of the metal guru's here could tell us. Here's the info on the makeup of the steels and the steels qualities.henhen14 wrote:i want to preorder a manix, but is BD-1 better than 154CM?
CTS-BD-1
Carbon 0.90
Molybdenum 0.30
Silicon 0.37
Chromium 15.50
Manganese 0.60
Vanadium 0.10
154CM
Carbon 1.05
Molybdenum 4.00
Chromium 14.00
Carbon (C)
• Increases edge retention and raises tensile strength.
• Increases hardness and improves resistance to wear and abrasion.
Molybdenum (Mo)
• Increases strength, hardness, hardenability, and toughness.
• Improves machinability and resistance to corrosion.
Silicon (Si)
• Increases strength.
• Deoxidizes and degasifies to remove oxygen from molten metal.
Chromium (Cr)
• Increases hardness, tensile strength, and toughness.
• Provides resistance to wear and corrosion.
Manganese (Mn)
• Increases hardenability, wear resistance, and tensile strength.
• In larger quantities, increases hardness and brittleness.
Vanadium (V)
• Increases strength, wear resistance, and increases toughness.
- chuck_roxas45
angusW wrote:I'm not sure but I bet one of the metal guru's here could tell us. Here's the info on the makeup of the steels and the steels qualities.
CTS-BD-1
Carbon 0.90
Molybdenum 0.30
Silicon 0.37
Chromium 15.50
Manganese 0.60
Vanadium 0.10
154CM
Carbon 1.05
Molybdenum 4.00
Chromium 14.00
Carbon (C)
Molybdenum (Mo)
Silicon (Si)
Chromium (Cr)
Manganese (Mn)
Vanadium (V)
Edge retention tests on several steels.
http://www.bladeforums.com/forums/showt ... p?t=793481
the photo shows 154cm. it also shows its a pinned construction vs screws except the pivot. so who knows? 154cm or bd1 ? not shure im diggin the riveted construction though. the clip is a nice change.
my knives:
kershaw Leek Buck 119 Cold Steel Recon tanto
Cold Steel Ti Lite VI ,
Spyderco: Tenacious ,Persistence, Endura 4 blue Stretch zdp blue, Manix 2 ,Native s30v . Sage2 titanium, Gayle Bradly cpm m4, Muleteam mt 10, woodcraft mule s30v. Orange Delica 4
Bark River PSK 154cm, Gunny, Bravo 2, Canadian Special
bada61265 wrote:the photo shows 154cm. it also shows its a pinned construction vs screws except the pivot. so who knows? 154cm or bd1 ? not shure im diggin the riveted construction though. the clip is a nice change.
The 2011 print catalog shows it as BD-1. Given the cheaper price point of this model BD-1 makes sense.
- SmoothOne25
http://spyderco.com/forums/showthread.php?t=46905RIOT wrote:some pretty trippy new ones coming out
http://www.knifecenter.com/kc_new/store ... paign=blog
- chuck_roxas45
and pinned construction.Tsujigiri wrote:I think I'll hold out and see if they make a completely clear version of the FRN Manix, like the prototype. Then again, it doesn't seem like this model is that much cheaper than the standard Manix 2, despite the cheaper steel and handle.
Not that I think that's cheaper but it's an undesirable for me.
- Left Hand Path
I think those are all in the 2011 catalog.RIOT wrote:some pretty trippy new ones coming out
+1jzmtl wrote:manix2 weights 2.85 oz! Would prefer a harder steel than BD1 thou.
I can be wrong, but even 440C looks better than BD1, more carbon and molly.
The only thing I can think of that FFG is more expensive than saber grindTsujigiri wrote:Then again, it doesn't seem like this model is that much cheaper than the standard Manix 2, despite the cheaper steel and handle.
- The Deacon
Main reason the G-10/154CM Manix 2 is such a bargain is that it's one of the models where Spyderco has been experimenting with a lower profit margin. Perhaps they're not doing that with the FRCP version.bh49 wrote:The only thing I can think of that FFG is more expensive than saber grind
- jujigatame
