Salt help
Salt help
Well I took my Pacific Salt to the beach and I guess some sand got in the crevices. I can hear the sand grinding every time I open the blade. Does anyone have any idea how to clean it out?
If there was one change I could make to this Salt line up it would be to make the blade screwed in instead of pinned so it could be taken apart and cleaned.
Thanks
Thanks
Welcome to the addiction
The newer of the salt series knives now come with screw construction for this very reason.
It is part of their "rolling change" so all newer models will have it. Cant really tell if your going to get screw or pinned.
I'd suggest giving the knife a good washing followed by blowing the pivot area with some compressed air. Give a good lubing and should be good to go.
Edit: http://www.spyderco.com/forums/showthre ... =sand+salt Heres a good thread
The same thing happened to my pinned Salt 1 after I wore it into the surf several times this summer. I just rinsed it out after each dunking. The gritty grinding disappeared with normal use after a couple of weeks, with no visible damage or scratching.
Not sure if mine was a mild case, or I just got lucky.
:spyder: C124GPFG/C101GP2/C11PGRE/
MT04P/C88PBK/C81FGD2P/C90PBK/
C36GPOR/C64JPBG :spyder:
- The Deacon
FWIW, the change to screw pivots is being made to make initial assembly of the knife by the maker easier. I'm sure there will be those who will take them apart for cleaning, but that's not why it is being done. In fact, I'm just about certain the same "disassembly voids your warranty" caveat that applies to all other Spyderco knives applies the the new Salts as well.cosmo7809 wrote:The newer of the salt series knives now come with screw construction for this very reason.
- chuck_roxas45
Take your gritty salt to a manual car wash. The high pressure spray will blow out the sand.
