Newbie
Blk_Ronin
Newbie
Post by Blk_Ronin »
Hi All,
I'm new to the Spyderco family, and was actually influenced into adding a knife to my EDC system are watching several videos by Nutnfancy on youtube...
Anyway, I've just got my first Spyderco blade, a Persistence (which btw is a great blade)... I live on an island in the Eastern Caribbean, and such was wondering if any of you have any advice on blade care in such a high sea-air environment.
Have no intention to go swimming/diving with my Persistence (but in hindsight should have opted for one of the H1 variations); notwithstanding would appreciate any advice on caring and maintaining my Spyderco.
Thanks...
kbuzbee
Post by kbuzbee »
H1 would have been my choice for that environment but a tuff cloth, used regularly should keep your knives in great shape. They even make a marine version for more extreme protection.
Which island?
Ken
( edit - oh and welcome to the forum!)
玉鋼
gmand16
Post by gmand16 »
I live near the ocean as well. I keep the blade oiled (it is porous). Check gun cleaning supplies, many work great on knives. I make sure to clean it often. Seeing as the salt is in the air, I would recommend storing it in a drawer or somewhere less susceptible to the environment while it is not in use. I have never had a problem with a blade rusting, same goes with guns I own. Maintenance is key. Treat it with care and it will not fail you. Often times, people run into problems because they were too lazy to take proper care of it, then complain when it does not work to their standards.
npueppke
Post by npueppke »
Any oil will work. Some people recommend mineral oil because it's non-toxic. I often use WD-40 as well (which is a bad lubricant but great protectant, as well as a degreaser).
DMgangl
Post by DMgangl »
I use mineral oil. Using an old soft Tshirt I put a little oil on the blade and wipe off the excess. I live on the coast and often walk the beach, never had a problem with rust.
DM
Smile, it can always get worse
Blk_Ronin
Post by Blk_Ronin »
Yup the H1 would have been the better choice, but I just loved the love and shape of the Persistence.
Oh, I'm currently living on St. Kitts.
Blk_Ronin
Post by Blk_Ronin »
Thanks all for the advice. Really appreciate it.
Blerv
Post by Blerv »
If you keep it oiled and wiped you shouldn't have a problem. At the least don't leave it wet or in a humid place.
A salt would be a great add in the future just as a "non maintenance" knife. That way you can keep the Persistence looking showroom clean and sharp all the time. :)
mrsteel
Post by mrsteel »
Oil the blade regularly (maybe after each heavy use)...
Welcome!!!
dbcad
Welcome
Post by dbcad »
Welcome blk ronin.
I've never had a corrosion problem with any of my vg-10 knives even if they've been in a salt air environment for a week or 2. I did look at them everyday to check though.
I think the Persistence is 18Cr13Mo?? Not sure from memory. I would think it's corrosion resistance would be pretty good.
Now for that environment I would have to have this :D
Charlie
Charlie
