Sometimes it happens
rycen
Post by rycen »
Was looking through some of my kitchen knives today and remembered that I had one that I was unsure what model it was. It was either a boning knife or a filet knife, depending on how flexible the blade was. So I decided to put a small amount of pressure on the blade to see how flexible it was. Guessing by it's lack of flexibility it must have been a boning knife. Sometimes though when you combine rust with poressure,this happens.
We would rather be the knife in your pocket, because is "works" better, than the knife in your showcase, because it "looks" better.
asfaltpiloot
Post by asfaltpiloot »
You didn't get hurt i hope?
Robert
"Never leave home without a knife,
one day it may save a life"
ChapmanPreferred
Post by ChapmanPreferred »
That is a shame. It looks like a pretty unregular break.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
Post by The Deacon »
Even a boning knife has some flexibility to it. Unless you really stressed it, which I doubt, I'd bet rust was the primary culprit. IIRC, there are some holes in the tang that the sermollan handle is molded through to attach it. Were there any such holes at the break point? Can't tell from the photos. Sad to lose one of those, they're one of the rarer Spyderco Kitchen Sharps.
rycen
Post by rycen »
I too believe rust was the culprit.I might see if I can det the handle apart to get a better look.
araneae
Post by araneae »
Have any plans to salvage the blade???? :)
-Nick
Last in: N5 Magnacut
tonydahose
Post by tonydahose »
thats a bummer. as for salvaging the blade..the only thing i can think of is weld a piece of steel onto it an putt a nice wooden handle. you might lose a little bit of the edge because you probaly would want to cover the weld with the handle.
WTC #1444 Always Remember
My knives
Spydie count: a few:D
Koen Z
Post by Koen Z »
Welding is not possible, it is a heattreated bladesteel!
O,just,O
Post by O,just,O »
Of course it's possible to weld that. I would weld it in two sec's.
Wrap the blade in a wet rag, weld, do not quench weld, but immerse rag & blade, leaving weld out of water.
Next step, do what Tony said with handle.
If you botch it, so what, it was broken anyhow. :)
O.
Hi Rycen,
I don't think the break was because of the flex. Looks like a corrosion issue. I think you should send it to us and ask Charlynne to call it to my attention.
