Mule Team Blade In!
gull wing
Mule Team Blade In!
Post by gull wing »
Just in! :)
It's very well done, I'm pleased with it. Much lighter than I expected(holes I guess). High quality work here, as the Sage is. Wish these people would have done the CATas well.
This is going to make a fine knife when I put those wood scales on and make a sheath. :D
SCARAMOUCHE! :bug-red-white
Sequimite
Post by Sequimite »
Mine came in today also. I put one side to side with an S90V Mule and the handle and all holes were in perfect alignment. The Chinese Mule has a few physical differences. It is sharp, but not as uniformly as my other Mules. It is much shinier and the holes are cleaner; the S90V like my M4 Mule has notches and burrs in the holes. The FFG blade is not as uniformly flat, you can see VERY shallow hollows similar to two 440C Chinese FFG knives I have. The 9Cr18 blade is about 1/16" longer than the S90V.
I don't think these differences are important.
Which is to say they still seem a fine value and after I bash one up, I may get more.
BuffaloBill
Post by BuffaloBill »
i may pick one up and try my hand with some paracord.
[SIGPIC][/SIGPIC]
^Click (needs updating)
ChapmanPreferred
Post by ChapmanPreferred »
I'm guessing tomorrow for me.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
VashHash
Post by VashHash »
mine is scheduled for wednesday hopefully i get my rescues, spins, and natives in wednesday maybe even my captain if the shipment came in. I also got the spyder decals with my mules
jabba359
Post by jabba359 »
Does anybody know if the whole knife is made in China, or is it just the steel that is imported from China and then Golden cuts them out of the sheets, grinds, and sharpens them?
It seems that it would be easiest to keep everything consistent (except the steel of course) if only one factory was responsible for all the finishing work that goes into turning the steel into a knife.
-Kyle
:bug-red
http://www.spydiewiki.com
dsmegst
Post by dsmegst »
My 6 came today. :) Just handling a few now.
Dan (dsmegst)
:spyder:
:spyder:
