I've got the MT03 & MT04 mules and an empty slot in my knife block. Which one do you think would make a better kitchen utility knife?
My wife is pesco-vegetarian so I won't be cutting through any meat bones on a regular basis.
Thanks,
Ira
CPM-S90V or ZDP-189 Mule for kitchen duty?
D3 CE, FG D4 CE Krein'd, Blue D4 FFG, Pink D4, Caly3 SE, USN E4 CE, Pink E4 CE, E4 ZDP-189 SE, FG E4 CE, E4 G10 FFG, Tenacious SE, Para SE, Para D2, Millie D2, ATR SE, Orange Assist I, Blue Rescue 93, Khukuri, Barong, Meerkat, Ladybug H1 SE, Manix 2 XHP, Rock Salt, S90V Mule Krein'd, JD Smith Sprint, Brown Matriarch SE, Poliwog, Stretch CE, Millie M4/Ti, Rock Lobster, Zulu, Rescue 79, D'Allara Rescue, LadyHawk SE, Lum Tanto Sprint, Dragonfly G10, Chaparral, Sage I, Caspian, Gayle Bradley
this is interesting
as i have some zdp and have not ever seen it discolor
other then the how stainless one blade over the other is
S90v would be better used on protein and the ZDP on veg. matter its all about the carbides and how there made
BTW you will likly not see any difference till you sharpen to over 4000 grit
Lloyd R Harner III (Butch)
a step forward
working my way to a licence to drill
http://www.harnerknives.com
a step forward
As Butch said, it is in the finer grits where you will see more differences. ZDP will get much sharper all the way to .05 micron, while S90V fights taking a polish. S90V will keep slicing for a really long time, especially if you leave a 1000 grit or so finish on it, while ZDP will be a great push cutter at fine grits. Basically, if you slice more I say go with S90V, if you do more push cutting then the ZDP would probably be the best choice.
Mike
Mike
