So, you have been buying mules, using them and comparing them. What have you found ?
Where are the mule reports :) There have been 4 different steels so far (if I remember correctly), and they've been in ELUs hands for a while, so there should be enough basis for comparison, right ?
What have you used it / them for , how are they holding up, what are your thoughts on how they compare ?
If you have not used it/them, what's the hold up !!!
I confess I am a slacker - I have 2 and don't carry them much because I still lack safe sheaths. I tend to use the knife in my pocket, so have not spent much time with them because they don't go in my pocket. I know that is lame, but my to-do list is fairly long and it is so much easier to just carry my D4 and paramil... :rolleyes:
But some of you are surely hard-core knife testers, so what have you found so far ? Just curious.
Where are the MULE reports ??
- The Mastiff
My use is pretty informal and the results I've had tended to be generalized , subjective things confirming what I already knew.
Example: Of all the "supersteels" CPM M4 is the one I can get the best edge on in the least amount of time. It seems like everything I've done has worked, and made it sharper. I love this stuff. Also, it doesn't rust as bad as a lot of people think.
etc. Not real scientific, I admit.
52100 reaffirms that bearing steels can make good blades. Very easy to sharpen. Takes great edges, and has good edge stability for a "high carbon" steel. Super easy to touch up. A classic steel for skinning blades for these reasons. Yes, it will rust. The finish has a lot to do with the rust factor. Near mirror polished, it will do pretty well.
ZDP: Amazing mule, breathtakingly sharp out of the box. I want more!
S90V: A true super steel that doesn't need high polished edges to cut. I am just as happy with it at 1000 to 2000 grit as I can be. Not as bad to sharpen as talk would have you believe.
Etc:
I also don't have time, or energy to do real objective, scientific testing. It doesn't lessen my enjoyment though. I think the mule team program is one of the best ideas in the industry ever. I hope it continues.
Etc:
- The Mastiff
Stay away from the bones with the ZDP.
