Lanyard Hole
Lanyard Hole
What is it?
Why is it there/Does it serve a purpose?
What does it do?
Or is it there just for looks?
What does it do?
Two main reasons.
I have a cord fob on my Mouse (like Chris Reeve's Sebenzas) to increase the effective length of the handle and make fishing it out of deep pockets easier.
The other type is the proper lanyard which is basically a cord or leather loop that fits around the fist or over the wrist to prevent the knife falling if your grip slips.
The only time the lanyard hole adds to the stregnth is when it is doubled up as a spacer to the handle, as seen on the Military. The more common type (hole drilled through the handle scale) can only take away from the strength, but not enough to notice.
"Walk softly, but carry a big stick."
Ah. It CAN give extra strength. On some lightweights where handle strength is still an issue, the lanyard hole can be reinforced with a metal tube to strengthen the butt end of the handle. This means that liners (which add to the weight and cost of the handle) don't have to run the entire length of the handle, or they can be eliminated entirely.
No Sharp I didn't <img src="smile.gif" width=15 height=15 align=middle>
I'll be sure to trot on over there when I get back... ugh going to the dentist...
*scrape scrape*
"Hey what do you use to sharpen these tools because the Spydero Model 204 Tri-Angle Sharpmaker can sharpen them."
*scrape scrape*
hehe <img src="tongue.gif" width=15 height=15 align=middle>
*scrape scrape*
*scrape scrape*
