Orange Rescue Info?
- Spyderwings
Orange Rescue Info?
Hi guys. I just picked up a 93mm Rescue today with orange FRN and ATS-55. Not sure if I'm going to keep it yet as I have a black VG-10 93mm already, but the store was going out of business so it was quite discounted. I haven't been able to find much info on this piece. i know it has been discontinued for a little while (2006 ish?). Anything I find on orange Rescues is on the new 79mm version that can still be found. Any thoughts on this piece? How much did they sell for when new?
- Jason Dalsgaard
Current Spyders > C81GPBK Para-Military > C14SBK Rescue 93mm > C11P Delica 4 > FB05P Temperance > C29S Cricket > C14OR Full Sized Rescue > C90CF Stretch II > C12SBK Matriarch (VG-10)
- anson argyris
If it's really ATS-55, it must be older. AFAIk, there were four generations of the Rescue model:Spyderwings wrote: I just picked up a 93mm Rescue today with orange FRN and ATS-55. i know it has been discontinued for a little while (2006 ish?).
1. with integral FRN clip and AUS-8 , handles in black , yellow and some other colors
2. with steel clip and ATS-55 , handles in black and orange
3. with steel clip, VG-10 and sort of a cutout at the spine of the blade, handles in black, blue and orange
4. same, just with a straight spine,handles in black and blue
- zenheretic
- The Deacon
ATS-55 steel would put it somewhere before 2003, IIRC. Barrel bolt clip means 2000 or later. Over the life of the C14, orange has been one of the two most common colors, the other being black. Believe MSRP would have been in the $65 - $70 range at that time.
- Spyderwings
Thanks for the info guys. And Anson, yes it is ATS-55. This knife has been in their display case for as long as I can remember. The only other Spydercos they had was a Byrd Cara Cara. (that sentence doesn't make a whole lot of sense...but I think you get the jist). I could tell that it had been handled a bit as the frn was dirty in a few places. Some hot water and paper towel took care of that in a matter of seconds though. And it definitely hasn't been used to cut anything, as I know that good factory sharpness quite well.
By the way, sweet pic Zen. Although you appear to be missing this particular version :p
- Jason Dalsgaard
Stainless Rescue is the Grand model
I've always been a fan of the Rescue model. My favorite one out of the ATS-55 era is the stainless handled version which is one of my all time favorite HARD USE Spyders. I was always perplexed why the stainless Rescue model had very little success in the sales charts :confused:
The Rescue model from what I've been told is an economical off-shoot of the old Original MARINER model ( the one I cut my Spyder Teeth on :D ).
Zen that's interesting you show those models with the dip in the blade. I'm truly ashamed to say that I never really knew the real reason for that particular blade design. I'm sure it has some functional advantage to it but I'm not sure what the lowdown is on it.
- ChapmanPreferred
- anson argyris
'We removed a crescent shaped portion of the spine that acts as a positioning spot for index finger control over the blade's tip.'thebestnoobcake wrote:sorry for resurrecting this old thread, but if i may ask, what purpose does the cutout int the handle scale serve?
Quoted from the Spyderco Catalog 2003
- The Deacon
Since he spoke of the cutout being in the handle, I think he was referring to the drying vent on the early Rescues, which was, as the name implies, intended to allow more air to circulate and dry the blade if it got wet. It was also possibly intended to make even more obvious the Rescue's connection to the Mariner.
