Oil Lub.....
azrida21
Oil Lub.....
Post by azrida21 »
I'm trying to find a good oil lub to use for my spydies. What do y'all use?
Any suggestions?
cyberspyder
Post by cyberspyder »
Tuf-Glide.
I BLEED TOXIC GREEN
:spyder: SPYDIE NUT
:spyder:
:spyder: Spyderco OG Manix PE
:spyder: Spyderco Black Dodo SE *gone*
:spyder: Spyderco Black Paramilitary PE *gone*
:spyder: Spyderco SPOT PE *gone*
:spyder: Spyderco OG Blackhawk SE *gone*
:spyder: Spyderco Ladybug/Photon *gone*
nicholaspoole
Post by nicholaspoole »
mineral oil on the pivot
CLP on the blade (apply liberaly, let soak overnight, wipe off excess)
SC14BK
C78BK
C109BKP
C115CFP
C122
C11GRE
and more too come
ozspyder
Post by ozspyder »
I use Inox, which is a fishing reel lube. Seems to work fine for me in lubrication, cleaning, and refreshing aged micarta etc. I have also tried Singer sewing machine oil and it seems to also be quite OK, though it is slightly more viscous and seems to attract a bit more lint !
Cheers
Doc Pyres
Post by Doc Pyres »
Fud safe mineral oil is what I use as lub :)
Hookpunch
Post by Hookpunch »
I use mineral oil
Welcome to the addiction
robin
Post by robin »
ballistol, it is named to be full natural, non poisoning (in ancient time hunters di take it aslo as a medicine) but is effective against rusting and patina....and smell good ;)
FLYBYU44
Location: in the wilds of Saskatoon, Saskatchewan, Canada
Post by FLYBYU44 »
I use Mineral Oil on all my knives
Those who choose to live a life without risks, arrive safely at death's door.
dalefuller
Post by dalefuller »
I use Tuff-Glide on the exposed metal of the blade and CRK grease on the pivot area.
Regards,
Dale
"If there are no dogs in Heaven, then when I die I want to go where they went."
~ Will Rogers, 1879-1935
spydutch
Post by spydutch »
Ballistol Kleber :cool:
Shike
Post by Shike »
azrida21 wrote:I'm trying to find a good oil lub to use for my spydies. What do y'all use?
Any suggestions?
The Search Engine is your friend :D
http://spyderco.com/forums/search.php
http://www.spyderco.com/forums/showthre ... ubrication
mark greenman
Post by mark greenman »
http://www.nanolube.com/ & http://www.diamondlube.com/Products.php
(inventors site)
Some guys on the fiveseven forum put this stuff in their barrels, added an extra 50 fps velocity :D Aparrently, it also reduced trigger pull by a few lbs, and worked well on one of their Benchmades.
Heres the thread:
http://www.57forum.com/viewtopic.php?f= ... 7&start=40
Anyway, I'm ordering some for sure come next paycheck
Militec & Sentry Solutions
Post by JD Spydo »
I use several different cleaning a lubrication products on my knives. Most of my use for lubricating moving parts on folders I use Militec synthetic oil. I use Breakfree & Ballistol for applications that require cleaning, lubricating and protecting.
I have used Tuf-Glide on occasions for different lubrication jobs. Tuf-Glide is made by Sentry Solutions who make a great line of knife, Gun & fishing reel maintenance products.
On very tightly machined stainless handled knives and/or automatic knives I use a dry lube made by Sentry Solutions known as BP-2000. I like it far better than graphite.
Again Militec and Sentry Solutions both make great products for what most of us in this hobby need.
Slick
We need a new sub-forum for FAQ's
Post by Slick »
Many topics come up repeatedly over time. This topic is an example.
An FAQ of these topics would be a good reference for newer visitors here. A well designed poll of forum members various choices could give an overall snapshot of what I might want to try.
On the downside is the extra time a new forum would add to Spyderco's time and cost.
The upside would be the consolidation of information and reduced threads that cover previously covered topics.
Edit: Not meant to be a highjack of this thread.
Not really all that slick ;)
vic2367
Post by vic2367 »
mineral oil
J Smith
Post by J Smith »
Militec-1 is the best lube I have ever used.
I use it on everything I have that needs lube.
[CENTER]0 0[/CENTER]
[CENTER]<[/CENTER]
[CENTER]\____/[/CENTER]
Capt. Carl
Post by Capt. Carl »
Tufglide for the pivots of my SS knives, mineral oil for the carbon steels and knives used with food.
fredswartz
Oils on knives and guns
Post by fredswartz »
For years I have used Tuf-Glide as a bore cleaner, preservative and solvent.
For lubrication and preservation the best thing that I have found is Birchwood Casey Synthetic Gun Oil. It comes out of the can clear and will absolutely lube and protect metal finishes especially long term. I swear by it.
Toro
Post by Toro »
I use Fluid Film.
http://www.eurekafluidfilm.com
IF you have yet to try it contact them and ask for a sample can.
:spyder: Dragonfly (traded)
:spyder: Centofante 3 (current edc)
:spyder: Native S30V (traded)
:spyder: Tasman Salt
:spyder: Rescue (gifted)
Water Bug
Post by Water Bug »
Hoppe's 9 Gun Oil.
