Page 1 of 1
Salt 1 reprofiling possible?
Posted: Fri Jan 18, 2008 2:38 am
by LOOKABIRD
i really like my Tasman Salt and I was thinking of buying a matching Salt 1. The only concern that I have is its tip. It seems really thick and curved downwards. Is it possible to reprofile it or should I not do that to H1?
Tom
Posted: Fri Jan 18, 2008 7:22 am
by Blackhair
You always
could, I suppose...
Personally, I prefer to use Salt knives as beaters, of sorts (which the thick tips assist with), and save the delicate work for other knives, like my Caly3. I've come to the line of thought that there is no
one knife for me that can handle
everything that I throw at it; and so I carry several.
In my opinion, the Salt1 is a great match-up with the Tasman, due to the Tasman's pointy hawkbill blade being a Yin to the Yang of the Salt1's more blunt, drop-point blade. I would get the Salt1 in SE, though, it seems to work a lot better.
Posted: Fri Jan 18, 2008 8:54 am
by bh49
LOOKABIRD wrote: Is it possible to reprofile it or should I not do that to H1?
Tom
I think you should have no problem to remove material with coarse or extra coarse stones, but it can take time. Not sure about effect of use of motorized equipment.
Posted: Fri Jan 18, 2008 2:36 pm
by SimpleIsGood229
bh49 wrote:I think you should have no problem to remove material with coarse or extra coarse stones, but it can take time. Not sure about effect of use of motorized equipment.
Either way, it should work harden. I know for a fact that Tom Krein can make it pointy.
Posted: Fri Jan 18, 2008 6:28 pm
by D-Roc
Die grinder would probably work- with a high quality attachment due to the types of steel Spyderco's use. :cool:
Posted: Fri Jan 18, 2008 7:59 pm
by LOOKABIRD
Could I just use a heavy grit whetstone to take off a lot of the material then polish it up with the sharpmaker stones?
Tom
Posted: Sat Jan 19, 2008 1:05 am
by MANIXWORLD
LOOKABIRD wrote:Could I just use a heavy grit whetstone to take off a lot of the material then polish it up with the sharpmaker stones?
Tom
i have made my SALT1 plainedge to a more pointy tip and using a diamondstone to do so :spyder: it has worked wonders,i used water in the process.i wouldn't advise using machines for the grinding process.it takes a bit of time,but the H1 steel,isn't that hard,which makes it easier :spyder: to grind by hand :spyder:
Posted: Sat Jan 19, 2008 9:38 am
by SimpleIsGood229
MANIXWORLD wrote:i have made my SALT1 plainedge to a more pointy tip and using a diamondstone to do so :spyder: it has worked wonders,i used water in the process.i wouldn't advise using machines for the grinding process.it takes a bit of time,but the H1 steel,isn't that hard,which makes it easier :spyder: to grind by hand :spyder:
I think MW pretty much has it. Get yourself a DMT X- or XX-Coarse and go from there with the Sharpmaker stones. A DMT Coarse wouldn't hurt as an in-between.
Posted: Sat Jan 19, 2008 1:13 pm
by Grey Mullet
I don't know. I do remember reading a post somewhere by someone who was felt that it would be necessary to reprofile both sides at the same time, or maybe go back and forth rapidly like on a Sharpmaker. The person who posted felt that if you tried to do one side, the blade would get warped due to work hardening before you got to reprofile the second side.
Posted: Sat Jan 19, 2008 7:10 pm
by Jazz
I did it to my Salt 1 and Pacific Salt - just used files, stones, sandpaper, and a strop to make it look like it was made that way - shiny and smooth.
- best wishes, Jazz.
