Show your Mule
Xplorer
Re: Show your Mule
#1481
Post by Xplorer »
Nice rack Andy :winking-tongue
@ckc_knifemaker on Instagram.
JRinFL
Re: Show your Mule
#1482
Post by JRinFL »
Gham wrote:
Sat Jan 29, 2022 6:21 pm
Was able to finish up handels and sheath this week not complete happy with the detal in the kydex maby next one I'll go a little hotter withe the kydex! Handles are fabric base bakelite and belt loop is a peace of old well used convayor belt!
Nice work on the scales and the sheath.
Gham
Re: Show your Mule
#1483
Post by Gham »
Thank you JRinFL! Hope to git my hand on some more mules in the near future!
LoPan12
Re: Show your Mule
#1484
Post by LoPan12 »
FullScaler
Re: Show your Mule
#1485
Post by FullScaler »
Carrying my MagnaCut on a hike today. Not much cutting but snagged a few nice pics.
Https://BladeProtection.com
Toker
Re: Show your Mule
#1486
Post by Toker »
I posted this in another thread, but wanted to add it here. Halpern Micarta scales (Deep Blue Sea and OD Green). Added titanium screws that I heat colored.
Resq52
Re: Show your Mule
#1487
Post by Resq52 »
:respect excited to test this blade our. I just finished the scales last night. Brown micarta with orange g-10 liner.
Xplorer
Re: Show your Mule
#1488
Post by Xplorer »
Resq52 wrote:
Fri Mar 04, 2022 2:38 pm
... I just finished the scales last night. ...
Nice work Resq52! The handle looks great!
standy99
Re: Show your Mule
#1489
Post by standy99 »
Great to see all these new Mule handles made by owners.
Good job Resq52
captnvegtble
Re: Show your Mule
#1490
Post by captnvegtble »
A pair of Magnacut Mules with burl ironwood scales... one was a gift for my teenage son, the other is a gift for me!
legOFwhat?
Re: Show your Mule
#1491
Post by legOFwhat? »
captnvegtble wrote:
Wed Mar 09, 2022 6:39 am
Wow! Those are beautiful Capn'! I just recently ordered some presentation grade burl ironwood myself, hope they turn out half that good.
How do get that slant at the thumb area close to the blade? I've seen quite a few mules with that and would like to try it myself if it's okay to ask. :cheap-sunglasses
-Larry
MNOSD #0049
z1r
Re: Show your Mule
#1492
Post by z1r »
Nice!
captnvegtble
Re: Show your Mule
#1493
legOFwhat? wrote:
Wed Mar 09, 2022 8:33 am
Thank you.
Are you asking about the thumb-index finger "pinch" area at the end of the scales?
I used a 1.5 inch diameter sanding drum attachment for my drill press (https://www.rockler.com/12-piece-long-d ... nt-sleeves). You have to sand that slant in before attaching the scales to the Mule, and then refine and smooth it out by lots of hand sanding after attaching and shaping the scales. I took the scales to a 1500 grit.
legOFwhat?
Re: Show your Mule
#1494
captnvegtble wrote:
Wed Mar 09, 2022 3:04 pm
Thank you.
Thank you for the tips! I'll give that a try.
-Larry
MNOSD #0049
Ramonade
Re: Show your Mule
#1495
Post by Ramonade »
Now that I have my belt grinder, I'll gain so much time ! I used to do wood handles for fixed blades only with rasps, knives, sandpaper and elbow grease. I've made an Amaranthe (Purple heart in english, IIRC) blank, to test my belt grinder and see where I'll put the Corby bolts.
It's a work in progress, the 45°is done, and then I entend to do the rest by handfor these "test scales". I had tried to follow the guard and blade ramp with the wood at first, but I wasn't pleased with where it was going.
I've finally found 10mm brass rivets, so it'll be used on the K390.
I'll certainly use the same 3/16" holes than captnvegtble for the Corbys on both Magnacut Mules, it looks better and require less material (thanks for the inspiration!).
Xplorer
Re: Show your Mule
#1496
Post by Xplorer »
Looking good Robin.
A belt grinder will definitely speed up the process. What belt size does your grinder use?
Ramonade
Re: Show your Mule
#1497
Post by Ramonade »
Xplorer wrote:
Mon Apr 11, 2022 9:10 am
Looking good Robin.
It's a small Sheppach, a German brand that does have an excellent Q/P ratio. The dimension are 25,4mm x 762mm, so 1" x something in inches ^^.
It's rather small, and it will limit some stuff but for handles it's quite nice. I've already started to do the first actual set of scales ^^ I'll try to upload a pic tomorrow.
Re: Show your Mule
#1498
You guys do some great work and I'm pleased to say that's the "Spyderco Way".
Ramonade
Re: Show your Mule
#1499
Post by Ramonade »
Here's a sneak peak at my first actual set of scales, it's stabilized but there's some gaps, the butt of the handle has two holes, I'm gonna try to epoxy it right after.
Xplorer
Re: Show your Mule
#1500
Post by Xplorer »
Epoxy is a good choice for filling that gap. In case you haven't tried it, I would also point out that C/A glue works well and will provide a clear and glossy surface when finished. It's best for small gaps and sometimes multiple coats are required. It's hard and can be polished but it's not very impact resistant so it's best for small cracks and crevices. The gap in the edge there might be a little large for CA glue but you can do it if you use tape to create walls to keep the glue from running out. CA glue is also handy because you can spray it with instant hardener and quickly move on to the next step.
