Page 1 of 1
Some Info On Aus-8 Please?
Posted: Tue Jan 15, 2008 6:55 am
by MANIXWORLD
Please can someone shed some info on AUS-8 bladesteel for me,WRT the stats of AUS-8 and with which other bladesteel, can it be compared?
Im familiar with using VG10,H1,154CM and SANDVIK steels.
I know its really not any steeljunky's favorite bladesteel,but some knife companies rate AUS-8 as there hi end steels.
I know Spyderco also uses AUS-8 in certain models,therefor im posting this in the Spyderco General Discussion thread.
Posted: Tue Jan 15, 2008 7:20 am
by JBE
You may be surprised at how many steel "junkies" actually like AUS-8 (aka 8A). It's really not a bad steel at all - easy to sharpen with "decent" edge holding properties; it's very similar to a fresh H1 blade that isn't work-hardened. As far as comparing to VG10, you really can't. VG10 really isn't any harder to sharpen then 8A and holds a fine edge much longer; VG10 is a very "balanced" steel property-wise. As far as 154cm and Sandvik, I can't offer much comparison because I've never owned blades in either, at least that I can remember.
Spyderco Steel Chart - you can compare properties of steels here. :)
You'll see that VG10 has a bit more carbon then 8A (think edge retention) and is a bit higher in other elemental properties such as chromium and molybdenum (think wear resistance/hardness)
Posted: Tue Jan 15, 2008 8:09 am
by MANIXWORLD
JBE wrote:You may be surprised at how many steel "junkies" actually like AUS-8 (aka 8A). It's really not a bad steel at all - easy to sharpen with "decent" edge holding properties; it's very similar to a fresh H1 blade that isn't work-hardened. As far as comparing to VG10, you really can't. VG10 really isn't any harder to sharpen then 8A and holds a fine edge much longer; VG10 is a very "balanced" steel property-wise. As far as 154cm and Sandvik, I can't offer much comparison because I've never owned blades in either, at least that I can remember.
thanx JBE,im always trying to up my knowledge on bladesteels-very interesting to know the different properties of different steels used in the knife industry today.
MW.
Posted: Tue Jan 15, 2008 11:30 am
by scout
JBE, very good comparison. Aus-8 is a great steel, just remember to remove the wire edge that forms during sharpening.
Posted: Tue Jan 15, 2008 6:28 pm
by jjacques
In my experience, you can get just as fine an edge on AUS-8 as any of the more "premium" steels. It doesn't seem to last as long as others, though.
As far as knives I've owned go, the edge-retention scale seems to be:
AUS-8 < VG-10 < 154CM < S30V
with D2 in the same ballpark as S30V if not better (I haven't had enough experience with it to be sure).
Posted: Tue Jan 15, 2008 7:17 pm
by sal
Hi Manixworld,
AUS-8 is made by Aichi Foundry in Japan. It has about 0.75% carbon, about 14% chromium, It has a little Moly, Nickel and Vanadium. All are in the "right" combination so the product's claim to fame is a very homgenous even grain structure. It will probably get as sharp as the best steels, just won't hold it as long as some of the super steels.
Posted: Tue Jan 15, 2008 10:02 pm
by carrot
I wouldn't call AUS-8 a premium steel... especially compared to VG-10, but it is pretty good and sharpens up nicely.
Posted: Tue Jan 15, 2008 10:15 pm
by yablanowitz
It may be a low end steel for Spyderco, but it is better than a lot of makers have at the top end. Sal spoils us with his steel offerings
:D
Posted: Tue Jan 15, 2008 11:27 pm
by gunmike1
It is very similar to 8Cr13MoV, but I have found the Byrd steel to perform better, possibly due to it being run harder than most AUS-8 that I have tried.
Mike
Posted: Wed Jan 16, 2008 4:44 am
by Zdenek
Not bad but ATS-34 and CPM's are (far) better.
Posted: Wed Jan 16, 2008 9:51 pm
by Agent Starling
scout wrote:JBE, very good comparison. Aus-8 is a great steel, just remember to remove the wire edge that forms during sharpening.
hey scout, is the "wire edge" the same as a burr?
Posted: Thu Jan 17, 2008 6:20 am
by bh49
Agent Starling wrote:hey scout, is the "wire edge" the same as a burr?
I am not scout, but answer is yes.
Posted: Thu Jan 17, 2008 9:28 am
by Cliff Stamp
gunmike1 wrote:It is very similar to 8Cr13MoV, but I have found the Byrd steel to perform better, possibly due to it being run harder than most AUS-8 that I have tried.
They are very similar :
http://www.cutleryscience.com/reviews/b ... #stainless
AUS-8A having a slightly lower carbon and higher chromium would be expected to be slightly softer (1 HRC) with increased corrosion resistance. However the differences are so small that the heat treatment variances would easily be what decided performance.
In reality, the main difference in these steels is nothing but marketing. Calling AUS-8A not a premium knife steel because you like high carbide steels is like saying P. J. Tomes is not a premium knife maker because you don't like the style of knives he makes.
-Cliff
Posted: Thu Jan 17, 2008 11:24 am
by scout
Agent S., Yeah, the burr on Aus8 tends to bend back and forth a lot if your unfamiliar with sharpening that type of steel. At first, I couldn't figure out my edges dulled so quickly. :confused:
Posted: Thu Jan 17, 2008 1:55 pm
by Cliff Stamp
The burr isn't inherent in the steel but how it is hardened. Have AUS-8A heat treated past 60 HRC and there will be no issues with burrs.
-Cliff
Posted: Thu Jan 17, 2008 2:59 pm
by Mr.S
The EDC that i carry for over seven month now has AUS-8 and i like this steel: it gets very sharp, it's easy to refresh this sharpness, there are no problems with chipping and it's very corrosion resistant.
Very good user steel, nothing special, but not bad!
