G-10 question
- LOOKABIRD
G-10 question
This may have been asked before but if I have blue G-10 is it possible to dye it black?
Tom
Tom
Spyderfly x2, Civilian G-10, Military CF S90V, Military CF BG-42, CalyIII PE CF ZDP-189, Military SE, Harpy SS PE, Merlin SE Black FRN, P'Kal, Tasman Salt PE Black FRN, Karambit, Cricket PE SS, Police SE SS, Ladybug CE Blue FRN
Wish List: Military Black Blade PE
BUY "ALWAYS SEARCHING" ON ITUNES!
IIRC this has bee asked before, a few months ago. I can't remember the correct answer though. I'd imagine NO, but if you do it'll be surface colouring and it'll wear off.
Daniel
Daniel
Cheers
Removed
Brad Southard
Southard Knives
Southard Knives
- The CoPilot
If you color your blue G-10 black, then what are you going to use in the final battle with the evil Smurfs?? :D :D :DLOOKABIRD wrote:This may have been asked before but if I have blue G-10 is it possible to dye it black?
Tom
><> The most important blood trail leads to the Cross <><
C09 CoPilots My Specialty
Integrity is Being Good Even if No One is WatchingTM
Looking for: C04 Executive plain edge, C09 CoPilot plain edge with brass liners and a G-2 marked blade
sal wrote:Hi Lookabird,
black leather dye will work on G-10. Also WD-40 will make the black G-10 blacker for awhile.
Well it seems I was wrong. Please excuse me. Sorry bout the miss information folks.
Brad Southard
Southard Knives
Southard Knives
- LOOKABIRD
Well, Tricod, I assumed the same thing as you and everyone else. If Sal hadn'm chimed in then I wouldn't have a Dodo at all! Now I need to go on a trip to the store and get it!!! :)
Tom
Tom
The typical alcohol-based leather dye may work, but it remains soluble in alcohol, not really "drying" like a paint.
FWIW, I have never dyed G-10, but I have dyed numerous leather projects. As I recall, black was always the most susceptible to rubbing off color. Blue was recommended as a base coat when dying leather to prepare it to accept the black dye. After dying the article black, a vigorous rubdown was required to burnish the leather and set the dye, followed by a clear coating to seal and protect the surface. Dying G-10, I would think that a sealer would be needed.
In any case, I would suggest trying it on some scrap G-10 first. Good luck!
Raqudu :D
Freedom is never a gift. It is the "pearl of great price" in anguish won.
[RIGHT]- The Theological Concept of Freedom[/RIGHT]
"Well, it's a nice soft night so I think I'll go and join me comrades and talk a little treason."
[RIGHT]- Michaleen Flynn (Barry Fitzgerald) in "The Quiet Man"[/RIGHT]
- LOOKABIRD
Will black leather dye make blue G-10 black?
It would make it black-er, but I don't think it would give an even, solid black color. My gut instinct is that the dye would settle into the low spots of the G-10 pattern and take very lightly on the high spots. With a little pocket wear, I think it would look more like an "antiqued blue" than a true black.
Again, my experience is with dyeing leather, not G-10. I would strongly suggest obtaining a bit of G-10 of similar texture to your knife and experimenting with the dyes you will use before trying them on the knife.
One other thing - don't forget the plastic gloves. Leather dye works very well on fingers. (I found that one out the hard way. :D )
Raqudu :D
:spyder: :spyder: :cool: :spyder: :spyder: If it's possible, I would like to know how it could be done! Great thought
:spyder: :spyder: :cool: :spyder: :spyder: "Spyderco...does a pocket good":spyder:
Spyderco Rocks!!!! "A wise man once said all knives were created equal...Obviously, he meant Spydercos''
As of 1-29-08, I am a proud member of Knife Rights!
