strength of the axis lock?
a while ago sal had the great thread on lock types and the axis lock was consided "very strong" i was wondering what this ment numericaly i.e.: foot pounds, etc and how this to the compared to the compression locks and strong lockbacks?
FTK
FTK
About the lock strength, how does that equate to other companies' claims of strength? For example, Cold Steel claims a lock will hold 120 pounds 4.5" from the pivot, or as far as possible. Is that the same test a Spyderco which holds 200+ completes? Or is there some other way of looking at this I haven't seen?
Thanks. <img src="smile.gif" width=15 height=15 align=middle>
Keepin' it real...real sharp, that is.
Spyderco has a machine that breaks locks in a very controlled and measured way.
MBC lock rating is 200# per inch of blade length. A 4.5" MBC Spyderco should thus be able to take up to 900# of presure before the lock gives.
The Cold Steel you mention takes 120# of total pressure, or 26.6# per inch of blade length. I don't think this would meet Spyderco's criteria even for "medium duty."
Edited by - Carlos on 12/16/2001 7:11:47 AM
We built our breaking machine to be able to test batches and determine if our locks were meeting our own standards.
Though we often break other companies locks, we do not feel that it is our place to make comments on their strength. If they are very strong, I don't mind giving credit for that achievement, but if they're not as claimed by those mfrs, then we prefer to keep our information to ourselves.
Sal, Thank's for the information. As far as real world lock strength
goes any well made "Locking Back" type of knife should be more
than enough for the "average" user.
That to me is ANY lock that engages the top back of the blade.
Liner locks are a different animal. I think where the average Joe
gets in trouble is expecting a folding knife to be as strong as a
striaght blade that is ONE piece of metal. With that in mind I'd
say that all of the name makers are careful enough to produce a
quality locking back knife that will serve all but the most severe
duty ( you need a straight blade work) safely.
There is no such listing as yet. I think that Spyderco considered stating that kind of information in their marketing/packaging of each knife, but I guess the ideas been dropped. The way marketing works in the US, I gues it would create more headaches for Spyderco than anything. Notice how every company wants to claim that their xxx lock is the strongest?
The Ayoob I believe is Heavy Duty rather than MBC, and some of the basic FRNs like the Endura are also Heavy Duty.
Carlos i think you are right if spyderco said a knife at X amount of # per inch another nife company might calculate the number a diffent way and if 400# of strengh is printed real big in red on an ad or on the box. that is what people will think. not reading the fine print staiting that the 400# is measured half an inch from the pivot point or what what ever gives them a good figure. thanks for every ones imput.
is there a machine that opens and closes the blade to test for repeat locking and unlocking?
FTK
Edited by - ftkinney on 12/18/2001 11:12:57 AM
FTK
I know this an old series of posts but I had to add my two cents worth while reading it because there seems to be errors in the calculations. First, the measures discussed here about lock strength seem to be measures of torque. A lock can support much more weight when the weight is applied right next to the lock than 4 inches from the lock. There is more torque applied in the latter scenario. 10 lbs applied one inch from the lock is equivalent to 10 inch lbs. 10 lbs applied 4 inches from the lock is 10 X 4 = 40 inch lbs. Now, I own many spyderco/cold steel/bench made/ zt/ buck/sog knives. I like the workmanship and locks if they are built well. But I wanted to correct what seems to be miss calculations in this thread. Sal states that a MBC blade must be in the area of 200 in lbs per inch of blade length. Say the Chinook 1 is tested at about 3.5 inches. That means the "strength rating" is 3.5 inches X 200 in-lbs/inch of blade length =700 inch lbs. If you compare apples to apples you have to be consistent in your units. Most knife makers that I've seen on compare lock stength in inch lbs. When cold steel says that a knive can support 120 lbs 4 inches from the lock, using sal's measure and units, that is the same as saying the lock is rated at 120 inch lbs per inch of blade from the lock. The measure of strength is then 480 in lbs and not the 26.6 lbs per inch described in a previous post. If the blade can support 235 lbs at 4 inches from the lock it strength is 4 X 235 = 940 inch lbs. That is the way it is calculated by alan eliswitz (sp?) when testing the hogue knife he designed and that is the same way it is calculated by Andrew Demko. Like I said before, I own a wide variety of knives, but let's be fair in terms of how we describe and calculate the numbers. Many knife makers make strong and beautiful knives.
It's awesome that Sal would give kudos to BM for the Axis Lock.
What I mean is that even classifying it in their realm for "MBC" says that the product matches the description. Sal and Co could have simply not responded keeping the mystery in our heads. I had no idea it was this strong and am impressed more with BM than before.
Sometimes there is more to being a good company than simply not saying bad things. Saying good things and tipping your hat at your competitors is a hard task. :)
- mikerestivo
Wow. Oldest tread ever.
Brad Southard
Southard Knives
Southard Knives
- defenestrate
- dialex
Indeed, this is something that bothers me as well. I mean, according to the statements above, if you have say a 4" blade knife, it will hold 4 x 200 lbs near the tip but only 1 x 200 lbs near the pivot? :confused:ghostguy1 wrote:I know this an old series of posts but I had to add my two cents worth while reading it because there seems to be errors in the calculations. First, the measures discussed here about lock strength seem to be measures of torque. A lock can support much more weight when the weight is applied right next to the lock than 4 inches from the lock. There is more torque applied in the latter scenario. 10 lbs applied one inch from the lock is equivalent to 10 inch lbs. 10 lbs applied 4 inches from the lock is 10 X 4 = 40 inch lbs. Now, I own many spyderco/cold steel/bench made/ zt/ buck/sog knives. I like the workmanship and locks if they are built well. But I wanted to correct what seems to be miss calculations in this thread. Sal states that a MBC blade must be in the area of 200 in lbs per inch of blade length. Say the Chinook 1 is tested at about 3.5 inches. That means the "strength rating" is 3.5 inches X 200 in-lbs/inch of blade length =700 inch lbs. If you compare apples to apples you have to be consistent in your units. Most knife makers that I've seen on compare lock stength in inch lbs. When cold steel says that a knive can support 120 lbs 4 inches from the lock, using sal's measure and units, that is the same as saying the lock is rated at 120 inch lbs per inch of blade from the lock. The measure of strength is then 480 in lbs and not the 26.6 lbs per inch described in a previous post. If the blade can support 235 lbs at 4 inches from the lock it strength is 4 X 235 = 940 inch lbs. That is the way it is calculated by alan eliswitz (sp?) when testing the hogue knife he designed and that is the same way it is calculated by Andrew Demko. Like I said before, I own a wide variety of knives, but let's be fair in terms of how we describe and calculate the numbers. Many knife makers make strong and beautiful knives.
- dialex
It's a locking mechanism designed by Mel Pardue (IIRC) and I think it was used for the first time at the REKAT Sifu. A variant of this particular lock is currently used by Benchmade for their Mini Ambush.VashHash wrote:What is the rolling lock
