Bob Lum Tanto question
I recently picked up a Bob Lum Tanto, among others at BLADE, however it doesn't quite line up. The forward edge is hitting the handle when I open or close it. The black is close to pristine, so I'd rather not screw it up, but how can I fix this?
Custom avatar courtesy of Dialex!
Bill Brasky could destroy Chuck Norris.
Just
Empty
Every
Pocket
Just
Empty
Every
In my experience, the longer the blade, the more likely this may happen. Have you tried giving the pivot screw a little tweak? This often helps, but there's a fine line between tightening it just enough and overtightening so the blade is too tight. I found it helped to tighten it up and then back off a bit. Sometimes, this will line the blade up better.
Dave
Dave
I have had 3 of those, all have had that problem. Perhaps Spyderco W&R would be able to help.
There isn’t any symbolism. The sea is the sea. The old man is an old man. The boy is a boy and the fish is a fish. The shark are all sharks no better and no worse. All the symbolism that people say is ****.
~Ernest Hemingway (describing The Old Man and the Sea)
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
