EMERSON KNIVES
STEVE-C48GPS
EMERSON KNIVES
HI ALL DOES ANYONE KNOW ANYTHING ABOUT EMERSON KNIFE'S I WAS LOOK AT THE CQC7BW-BTS I ALSO HAVE HEARED THAT THEY ARE REALY HARD TO SHARPEN IS THIS TRUE AND WHY?
kraziekurtis
Emerson knives are great. I own 3 of them and they haven't let me down yet. They are top notch on customer service and they have pretty high quality products. Alot of people have trouble sharpening the chisel grind. I have not. I use an alumina ceramic rod and follow the instructions on the website:
www.emersonknives.com
Also, check out bladeforums.com for info, check out the Usual Suspects and the Emerson forum. While you are there, also check out the Spyderco forum, great info!
Matt
Matt
I have a waved CQC7, and it is a great little knife. Right now it's one of my EDC pieces, the only problem I encountered with it was trying to strip some wire while under my house... the chisel grind sucks for that job. Luckily I had another knife on me, and it did the job without any trouble.
You shouldn't have any problems sharpening it if you can sharpen most other ATS-34/154-CM knives. The 154CM from emerson is supposed to be a lower hardness than most others, which should translate to easier sharpening, more often.
