Sharpmaker Q
Sharpmaker Q
I was wondering if anyone else has this problem. I've really made good use of my sharpmaker in the last couple of years I've had it, but it's getting to the point where if I try and sharpen something with the white stones, the points on it get gummed up with metal dust after only a few strokes. I take them out and clean them with some Comet cleanser and a sponge until they're white again, but then after just a few minutes, it's gummed up and not functioning as well as it should once again. Have I messed up my stones or is this just something I'm going to have to get used to? Even with this problem the thing is still lightyears ahead of the plain old Arkansas stones I once used. Thanks
Good question Zeppelin.
I discovered the same thing with my white stones :confused:
....AND A FG(PARA) MILITARY/SE IN CPMD2(thanx Sal)
I have an old 203 Sharpmaker and have noticed the same thing with the whites. Maybe it's just a long-term effect from all the sharpening (esp. with the harder, modern steels) causing the whites to lose some of their "fineness" and becoming a bit coarser. Or it could be that the knives you're sharpening have their angles set over the long-term from using the Sharpmaker and your hand positioning and are now having more of the edge abraded by the stones.
I noticed this only on the corners of white stones. Especially they are getting saturated fast when I sharpen serrations. I use Mr. Clean eraser to clean corners. It is work great, just one pass.
