Folding Perrin Street Beat
v34
Post by v34 »
Been playing with the FB for a while and feel it is screaming out for a folding version.
Same handle with the pivot point above the finger choil and a simple lockback following the curve of the micarta helmet.
Sal?
dedguy
Post by dedguy »
I'd be down for any Perrin folder.
"Always keep an edge on your knife son, because a good sharp edge is a man's best hedge against the vague uncertainties of life."
dedguy.net
merciful
Post by merciful »
Count me in.
spiderGent
yesyesyesyesyesyesyesyes
Post by spiderGent »
please, i love the street beat a folder would be great!!!!!!!!!!!!!!!!!!!! :D
" THE WORM IS THE SPICE "
Puyallupknifegu
Post by Puyallupknifegu »
I would dig a folding version... :D
T :D
God bless!
-Puyalluknifeguy-
Si Vis Pacem Para bellum
Stenny
Post by Stenny »
If affordable and waved, count with me.
Piet.S
Post by Piet.S »
A pivot point above the choil would be way to high.
If you make a few copies of a picture of the Streetbeat you can see why.
First you cut out the handle shape.
The next one you cut out the blade with a bit extra to be the tang.
Put them together with a needle or a toothpick as a pivot point and see what happens if you fold it.
All your knifelinks, http://www.knifelinksportal.com
Post by The Deacon »
Piet.S wrote:A pivot point above the choil would be way to high.
Or lengthen the handle and put the pivot about where the first pin is now. But you're right, it would not be practical without modifying the Street Beat considerably.
Closest existing Spydie to the blade shape would be the Blackhawk. Perhaps an updated version of that, with a full flat grind, jimped spine, an more "flat" to the edge with a tighter radius curve to the tip would be a viable alternative.
ATR216
Post by ATR216 »
Wouter,
Excellant pictures and review.....William
P.S. G-mail is offline. Please use my alternates to contact me. I cannot find
your info!
I've seen a few designs that were similar to what you describe. I think Chad Los Banos was working on one.
We would have to see something that Fred Perrin would create.
