Thanks to the generosity of Gunmike1, my unworthy self is EDCing a D'Allara Drop Point. The steel-lined FRN feels more rugged than steel-lined G-10 or micarta. The palm swell fills my hand comfortably and securely in every grip I've tried. The hollow-ground VG-10 blade is thick enough to be rugged and thin enough to do everyday cutting tasks (a little thick for my tastes, but I'm not thinning it; Thomas Welk has corrupted me into finding the beauty of the original geometry of my knives - I'm trying to corrupt him with a wafer-thin ZDP D4). The wire pocket clip and area on the scale it touches hold the knife in place a little without threatening to eat pockets. The action is smoother than melted butter over glass even when the pivot is cranked down as tight as can be (smoother than the Caly3, even). The Ball-Bearing Lock passes spinewhacks and has twisting and light fouling removed from the list of lock defeaters (are you listening linerlocks and lockbacks?
). The swelling at the pommel area allows for instant retrieval and indexing, though at the expense of making it difficult or unwieldy to implement a Caly3/UKPK/Meerkat deep-cary wire clip.
Due to the shape of the handle, the sturdiness imparted by its steel-lined FRN scales, and the stout-but-efficient saber hollow-grind, this knife just feels like a beast. Cuts hardwoods like a beast, too. Just opening the knife prior to cutting makes me feel like State Trooper Arcot Ramathorn right after he drank a caraffe of maple syrup:
" wrote:I'm all that is man!
Thanks, Gunmike1 and Spyderco, for such an awesome blade!
The bottom line is that if you want something tougher than a Delica, Endura, or Caly3 (and why should you? What's the matter with you? Are you that ungracious of all the cutting those knives let you do? When I was a kid, I had to cut with a competitor's knife both ways in the pouring sleet), the D'Allara Drop Point offers the smoothness and refinement of some select high-end knives with the ruggedness and performance of other high end knives (not naming the brands, either, so nyah!) with a look and sharpness that is uniquely Spyderco. And it costs $200-400 less than those knives and has a more reliable lock, too!
