Proto Photos - Salsa & Jester
bcaffrey
Post by bcaffrey »
You guys asked & Sal graciously said yes so here are some proto pix from the NY Custom Knife Show.
Cheers,
Brian
<a href="/forums/attachmentarchive/2631-7-SpydercoJester-small.jpg" target="_new">View Attachment...</a>
<a href="/forums/attachmentarchive/2631-7-SpydercoSalsa-small.jpg" target="_new">View Attachment...</a>
kraziekurtis
Post by kraziekurtis »
I like Image 2 the best!!!
scolby
Post by scolby »
I like the jester - good job Spyderco. Kind of a modified Worker/Wegner Jr. blade - looks very usable.
I like the burgundy micarta too.
"Chance favors the prepared mind" - Louis Pasteur
kraziekurtis
and another plus is that it is small like the size of a ladybug!! <img src="smile.gif" width=15 height=15 align=middle>
vampyrewolf
Post by vampyrewolf »
it's a wegner jr, jr...
I'll be buying at least one for myself.
We all start with 10 fingers. Those with Spydies have 9 to spare, Still need a thumb. Good thing I still have 8 to spare...
sam the man..
Post by sam the man.. »
The salsa's really HOT~! <img src="smile.gif" width=15 height=15 align=middle>
Sam
have spydies will travel
chinook
Post by chinook »
Nice.....
Butt I wish it had a bit more of a point for fine work.
Disguised as a responsible adult
J Smith
Post by J Smith »
Well salsa first then jester. when will they be in the stores.How much will they be?
Is there a clip on the jester?
Jeff
Edited by - J Smith on 11/4/2001 9:03:09 AM
Kahz
Post by Kahz »
Jester looks fine. What are the characteristics? Steel, length, weight, etc.? Price? Will it come in other colours? Like previously asked, does it have a clip?
Thanks.
Kahz
"Never trust machinery more complicated than a knife and fork." -R.A.H.
bcaffrey
Post by bcaffrey »
Sal will have to fill in the details but I don't recall seeing a clip on the Jester. I do remember him saying it will be a limited run so, if you guys want one, don't hesitate or you may be disappointed.
Cheers,
Brian
Sheeple
Post by Sheeple »
Mr. Glesser,
I humbly bow to you for your graciousness, your generosity. You truly hear those who call upon you and answer our heartfelt pleas.
I have begged in the past (forgive me for my oftenwavering faith) for such creations: flat ground Co-Pilotish knife and a plain-edge in the Ladybug size.
To see both come to fruition on this very thread is too much for me.
Thank you, sir! Now where are those Kleenex...
Sheeple
Post by Sheeple »
Mr. Glesser,
Sheeple
Post by Sheeple »
Mr. Glesser,
Thanx for the pics Brian. Nicely done.
Thanx also for the kind comments.
Chinook, The "trade off" between fine tip (often broken) and wider or thicker tip for strength is always an issue. In the Salsa, I made the tip wide so it could still be thin. The Jester is a little wider and a little thicker than the Ladybug tip.
The actual Jester model will be FRN, available in March 2002, in 3 colors with AUS-6 in the blade. No clip. It is the same overall size as the Ladybug. Should be a nice key chain or "loose change" piece.
The micarta version is just a preliminary variation for which only 1000 will be made.
The "Salsa" has an Anodized aluminum version in blue, green and a gray/tan. Nested Compression lock, AUS-8. The Titan version has an integral compression lock and is ATS-34.
The wire clip is left/right on the aluminum version, but the Ti version is right hand only. sorry 'bout that, making the holes for the left hand version of the integral lock version would affect the lock spring.
kraziekurtis
What colors will the Jester be in?
Please say green come on green <img src="smile.gif" width=15 height=15 align=middle>
