Tip up or tip down?
GradeMaker
Tip up or tip down?
Post by GradeMaker »
On knives where you have a choice, say the D4, what's your preference? I've noticed that most D4s come RHTU except SS models which seem to come RHTD. I'm RH and for deployment TU seems a little more convenient but in the same vein TD seems to "fit" a little better in my pocket. What's your preference and why?
meat
Post by meat »
I like tip up, because it seems more natural to me and that is what I am used to. With the Wave versions, you want them in tip down, for the wave feature to work correctly.
denn
Post by denn »
always "RHTD".
i'm right-handed, and tip-down drawing just works for me like a charm. never gotten quite used top tip-uppers (well, maybe some small spydies....) and i don't like the blades of tip-uppers on liner- and compression-locks to partially open in my pocket
you get the drift what happens then........ouch.
Simple Man
Post by Simple Man »
Tip up, too much dust and grit gets in the pivot with tip down.
Romans 8:31 ....If God is for us, who can be against us? - <><
The Spyderco hole is a rotating mechanical assembly of one part.
".....tractors don't have to look like Ferraris" -Sal
zenheretic
Post by zenheretic »
meat wrote:I like tip up, because it seems more natural to me and that is what I am used to. With the Wave versions, you want them in tip down, for the wave feature to work correctly.
Sorry meat, you need it tip up for the wave to work. ;)
Follow the mushin, but pay it no heed.
bh49
Post by bh49 »
I prefer tip up. For me it easier to open.
eastr
Post by eastr »
It's tu for me seems to work best on smaller models haven't made up my mind for the lager models.When they are td you can get to the whole quicker. when its tu it seems to take more time to get your hand inposion and get to the whole. :cool:
"THE ROUGH RIDER”“FAR BETTER IT IS TO DARE MIGHTY THINGS..THAN TO TAKE RANK WITH THOSE POOR. TIMID SPIRITS WHO KNOW NEITHER VICTORY NOR DEFEAT.” THEODORE ROOSEVELT 1899
spyderco making mans oldest tool mans most advanced tool:spyder:
THE GREATSET POWER IS OFTEN SIMPLE PATIENECE
The only thing necessary for the triumph of evil is for good men to do nothing.
gordonk
Post by gordonk »
Tip up on my smaller blades and lefty ideally :) On my larger blades, I'm fairly neutral there as I don't use them that often.
- gord
Michael Cook
Post by Michael Cook »
:spyder: It's gotta be tip-up. I'm a mbc player, tip up gets the blade into action a half beat faster. :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
Kaizen
Post by Kaizen »
RHTU generally. I always liked the option of "waving" a knife, so I guess I tended to go tip up in the case that I did modify a knife (which STR did to my Pacific Salt). So I just got used to it in time. I'm sure I can get used to any position if I want to.
Saint-Just
Post by Saint-Just »
†ip up with Tasman, tip down with Caly jr and Manix, both RH and I am mostly lefty (quite ambidextrous, but primarily lefty).
I find both tip options as easy 1) to get used to and 2) to open knife .
C'est magnifique, mais ce n'est pas la guerre!
Gal. P. Bosquet, 25th Oct 1854
Firefighter880
Post by Firefighter880 »
I almost always go with tip up if I can. ANY Spyderco that has the option gets converted to tip up. For me, it just seems like I can access it faster that way... but then again, it's just a personal preference.
Something funny I did notice, almost all of my knives are :spyder: , but I do own a CRKT M-21 that I use as a beater knife. The M-21 has the option to go tip up, so I converted it. Changed it back to tip down a day later. Something about that particular knife just made me hate it tip up. It was harder to get to, and just didn't feel right in the pocket... so I guess it depends on the knife as well.
[CENTER][SIGPIC][/SIGPIC][/CENTER]
[CENTER]"Courage is not the absence of fear, but rather the judgement that something else is more important than fear." [/CENTER]
Current Spyders: Civilian, Matriarch, Endura 3 CE, Endura 4 CE, Endura 4 SE, SS Endura 4 SE, Lava, Manix CE
Spyders of the Past: ATR, BlackHawk, Bob Lum Tanto, Chinook 3, Dodo, Gunting, Karambit, Lil Temp, Manix PE, Para Mili, Ronin, Yojimbo, Mili, Native
Tlohm
Old habits die hard
Post by Tlohm »
Tip Down. Using the Spyder Draw or Flick or snap or what ever you want to call it. With a little practice you can deploy the blade faster than any automatic ever dreamed and at least as fast as with the wave. If you ever get the opportunity to have Sal demonstrate it will blow your mind. You grasp the hole and draw out of pocket and open in one fluid motion.
Today matters, don't waste it. There is no second chance.
Axlis
Post by Axlis »
[quote="zenheretic"]Sorry meat, you need it tip up for the wave to work. ]
Maybe he knows something we don't. ;)
Axlis
Post by Axlis »
Tip down is my general preference, although I gotta say that I have no complaints with the Caly III. :)
ront
Post by ront »
I prefer TU but can go either way.
Ron
bigkahunasix
Post by bigkahunasix »
Carried both, Preference is
SD primary- tip up, just more comfortable/natural on deployment. I have 2
G-10 police that I have converted to TU for this purpose.
Utility- either way.
Been packing at least two Spyderco knives a day since 1984
[SIGPIC][/SIGPIC]
smcfalls13
Post by smcfalls13 »
Tip up primarily, but if like the knife, I'll "suffer" with tip down.
:spyder: Scott :spyder:
"We make a living by what we get, we make a life by what we give."
-Sir Winston Churchill-
denn
Post by denn »
Tlohm wrote:Tip Down. Using the Spyder Draw or Flick or snap or what ever you want to call it. With a little practice you can deploy the blade faster than any automatic ever dreamed and at least as fast as with the wave. If you ever get the opportunity to have Sal demonstrate it will blow your mind. You grasp the hole and draw out of pocket and open in one fluid motion.
my thoughts exacty
i put $5 on it that i can beat Sal on the speed of draw :)
Michael Cook
tyrain hard and stay safe!
Tlohm wrote:You grasp the hole and draw out of pocket and open in one fluid motion.
:spyder: But then one needs to shift the blade to a usable grip, tip up opening allows the blade to be ready to go as soon as the blade snaps open. Opinions vary and nobodys wrong for having a preferance but I do believe for MBC purposes tip-up will get the blade into play a hair faster. For non MBC/SD uses I doubt it matters much. :spyder:
