Chipped
Vincent
Chipped
Post by Vincent »
Since I have gotten my Lil temp it has fastly become a faviorite carry, I am always carrying it and have not carried anything else since. I havent used this knife for anything out of the ordinary, not like other knives.
Opening boxes, cutting cardboard, mostly standard work.
But even with standard usage I got a chip in the tip and dont really know what to do since its so close to the tip.
here is the pic.
bh49
Post by bh49 »
Is it S30V or 440V?
Vincent
Post by Vincent »
bh49 wrote:Is it S30V or 440V?
s30V my man
Halfneck
Post by Halfneck »
Looks like you could re-profile it.
"A Delica is still a better weapon than a keyboard and a sour attitude..." Michael Janich
bh49
Post by bh49 »
I had similar problem with my Native. There were several threads on BF about 7-8 month ago about chipping of S30V due to heat treating or final grinding.
There is a good chance that reprofile will help, it helped me back in December and I never had this problem again.
Good luck
rcbalt2
Post by rcbalt2 »
Reprofile it that should fix it right up.
There ain't no rules around here. We're trying to accomplish something.
- Thomas Edison
dedguy
Post by dedguy »
i had similar damage to the tip of my VG-10 harpy admitedly from slamming the tip accidentically into some concrete while cutting down boxes. sent it to Golden and they reprofiled it.
"Always keep an edge on your knife son, because a good sharp edge is a man's best hedge against the vague uncertainties of life."
dedguy.net
Zac
Location: Lutherville, Maryland, USA, Earth, Solar System
Post by Zac »
gonna have to be reprofiled...did you sharpen it before using it?
WARNING: Sanity not guaranteed.
Vincent
Post by Vincent »
Zac wrote:gonna have to be reprofiled...did you sharpen it before using it?
no i havent sharpened it yet.
Fred Sanford
Post by Fred Sanford »
Hey bro,
That's no big deal. I did that to a BM I had with S30V. I just sharpened it out. Took about 40 minutes on a Lansky.
For some reason (at least with certain knives) S30V behaves better after it's first sharpening. :)
Mr Blonde
Post by Mr Blonde »
Looks minimal, I'd try to sharpen it 'out'.
Wouter
Last website update: 04-19-2026 Instagram
Zac
Post by Zac »
Vincent wrote:no i havent sharpened it yet.
:-/ I usually sharpen S30V knives before using as I have heard that can eliminate chipping. You may be able to diamond it out. If nothing else, Spyderco will hook you up but they are backed up :(
GarageBoy
Post by GarageBoy »
Just let it be. Don't bother reprofiling, just sharpen normally and it'll be fine. Cutting bus seats again? =D
Joe Talmadge
Post by Joe Talmadge »
Just sharpening out seems to be the right thing to do, given all the reports of this happening on fresh S30V edges, but ceasing to happen after a sharpening or two. Doesn't seem to be any reason to re-profile ... what's leading to the re-profiling suggestions?
spyderknut
Post by spyderknut »
Having a single serration near the tip like that probably aint too bad. I vote to sharpen it too.
"There's no such thing as bad weather, just bad clothing." -- my grandfather
Collector #041
Michael Cook
Post by Michael Cook »
:spyder: I had no idea s30v works better after first sharpening. I always do that as I like a more polished edge and I've never had chipping issues. Maybe that's why! :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
Zac
Post by Zac »
Michael Cook wrote: :spyder: I had no idea s30v works better after first sharpening. I always do that as I like a more polished edge and I've never had chipping issues. Maybe that's why! :spyder:
It's reccomended and I've always followed it. I've never had a problem with that steel and I have had problems with other (my foot can vouch)...
yablanowitz
Post by yablanowitz »
Most of the factory edges I have examined on decent knives (not just :spyder: ) seem to have a wire edge. It is very sharp, but that wire has been worked back and forth during sharpening and is fatigued and brittle. If all you are doing is slicing the occasional lime for your Corona, it works OK, but it can be chipped pretty easily. A good sharpening (taking off that fatigued metal) to reveal fresh steel will usually take care of this problem, and it shouldn't happen again. I have had similar things happen with S30V, 440C, ATS34/154CM, and even ZDP189, which is why I usually sharpen my knives before I use them (unless I am testing a new brand or steel). Interestingly enough, the factory edge on my Byrd Flight stood up better than the one on my ZDP Delica. Go figure :rolleyes:
dialex
Post by dialex »
Thanks for the infos. I have a couple S30 knives that didn't cut anything (well, bread or a tomato and this just for demonstrational purposes ;) ) so I wasn't aware of this issue.
Edgy
Post by Edgy »
For such a small chip, about 5 minutes with a medium diamond stone would take that right out. Finish it up with a fine grit stone and celebrate your new tip :D
