Having trouble using a basic SharpMaker set to sharpen a humble machete. I am following the user guide instructions for kinves. Any suggestions as to how to best accomplish this task? Always great results before this time.
riverworld
Machete Sharpening
riverworld
Sword and Shield
Hi, riverworld! Welcome to Spydieland!<img src="smile.gif" width=15 height=15 align=middle>
I would use sandpaper and a block of wood to sharpen a thick blade like a machete. Fix a piece of sandpaper to a block of wood, then sharpen blade like you would on a regular stone.
100 grit, then 200 and 240 tends to work very nicely on working edges. Good luck! <img src="smile.gif" width=15 height=15 align=middle>
Keepin' it real...real sharp, that is.
Edited by - Sword and Shield on 9/16/2001 2:31:51 PM
Michael Janich
Dear Riverworld:
I like to clamp my machetes to a bench so the edge just hangs over the front of the bench. Then get a fine flat mill file (longer ones work best) with a handle. Take the handle off and cut a disk of 1/4-inch plywood about 4-6 inches in diameter. Drill a hole in the center large enough to go over the tang of the file. Place the disk on, then replace the handle. The disk will now act as a hand guard to keep you from cutting your hand.
Now gently file the edge of the machete in a series of push strokes until you cover the entire edge. Flip the machete over and repeat the process on the other side. This should give you a sharp edge with a pronounced burr.
Clamp your Sharpmaker in a vise so you can work the machete with both hands and sharpen the blade in sections as you would a regular knife. This should produce good results.
Stay safe,
mike j
Stay safe,
mike j
riverworld
riverworld
