what about a spydie friction folder ???
arzh
Post by arzh »
HI
is there in the past a poject about a friction folder with this kind of system?
fred Perrin
this one pierre henry monnet
this one by filip De Leeuw
i imagine for the design
the manix
or the Uk pen knife
tell what are you thinking about it
cheers
arzh
Mr blonde's website fan's :spyder:
http://www.spydercollector.nl
BlackNinja
Post by BlackNinja »
That would negate the :spyder: hole, no! :confused:
The UKPK is a friction folder.
Let your opponent graze your skin and you smash into his flesh;
Let him smash into your flesh and you fracture his bones;
Let him fracture your bones and you take his life!
-Bruce Lee-
-Joe
dedguy
Post by dedguy »
i was under the impression that the UKPK was a friction folder. there's also the rare earth magnet folder coming soon.
"Always keep an edge on your knife son, because a good sharp edge is a man's best hedge against the vague uncertainties of life."
dedguy.net
smcfalls13
Post by smcfalls13 »
Anyone want to explain a friction folder to me?
I'm of the mindset that if it doesn't have a lock, it's a slipjoint. Could someone enlighten me as to the difference between a slipjoint and a friction folder? :confused:
:spyder: Scott :spyder:
"We make a living by what we get, we make a life by what we give."
-Sir Winston Churchill-
arzh
Post by arzh »
BlackNinja wrote:That would negate the :spyder: hole, no! :confused:
yes you are right need no hole
this system is calling in french "pièmontais" it's one kind of friction folder
the uk pen knife is callin in french "cran forcé"
if senate ou twann can explain the difference in english
it will be cool
thanks arzh
inzane
Post by inzane »
i feel stupid but what exactly is a friction folder?
Post by The Deacon »
I beleive that a slip-joint always relys on a spring, pressing against the edge of the tang to hold the knife both open and closed. Whereas a friction folder relies, in effect, on a very tight pivot to "squeeze" the sides of the frame against the sides of the blade tang to keep the knife closed. That pressure is often augmented by some other means of keeping the knife open, so it will not close unexpectedly. The split ring on an Opinel, or in the case of the knives above, the "finger" coming off the back of the tang.
smcfalls13
Doesn't seem like a very good idea. I would think a friction folder would loosen up MUCH faster than a slipjoint.
I must be missing the appeal... :confused:
Senate
Post by Senate »
I'm not sure but I think Deacon's pretty much covered it, tight pivot pin and the long piece of steel prolonging the tang of the blade which is supposed to go in the spine the knife and will be blocked by the hand. this kind of "lock" is made for a cutting only in a normal grip position.
Alexandre.
Nemo3000
Post by Nemo3000 »
Hi,
during Eurosatory, three weeks ago, I have given a friction folder to Olive for her to give it to Sal !
It's a Xavier Conil piemontais knife called "Couteau Des Sorgues", designed 10 years ago. The blade looks like the Chinese folder and cuts like a devil.
I love that knife so much, I took my chances and proposed it to Spyderco R&D to have a closer look at a modern Piemontais Design (handmade in the Vaucluse) :cool: .
Perharps it will turn into another collaboration. I don't know.
But for your information I made my homework for that ! Friction folders rules ! :D
cheers
Nemo
thombrogan
Post by thombrogan »
Scott,
The friction of one's hand keeps a friction folder open. Think of the Spyderfly as sort of a friction folder. A slipjoint requires one to slip the blade out of joint from the backspring to open or close the blade.
Nemo3000 and Arzh,
I wish you great success in convincing Spyderco to make a friction folder.
"I knew you before you knew you had hands!" ~Tracey Brogan
"Ah-ha! A Spyderco moment!" ~Michael Cook
"Hawkbills - Sink in the tip and let it rip!" ~Axlis
"I would rather have questions that can't be answered than answers which can't be questioned" ~Richard Feynman
smcfalls13
thombrogan wrote:Scott,
So basically the knife utilizes your hand as a locking system? I thought it was just the friction of the pivot that held the knife, but if most of them have that appendage on the blade for the hand to block, than it sounds like a pretty good idea.
Thanks for the explanation. :cool:
arzh
Post by arzh »
Nemo3000 wrote:Hi,
cheers
Nemo
hey Nemo
very great choice
this is the "lame des sorgues" here in pics
here my personnal
a pimped version by xavier Conil
My first question would be, how are these normally carried? I would think the projection (by the way, what is that called?) that serves as both an opening device and lock would make normal pocket carry impractical. It would also rule out tip down clipped carry, and tip up would seem extremely risky. A sheath / holster of some kind would appear to be the only practical carry method.
Unlike Opinels and Laguioles, which have a certain fluid grace to them, but aside from the wood handled one which has a certain primitive charm, I don't find anything the least bit appealing about these.
dialex
Post by dialex »
Thanks, but no thanks. Not my cup of tea, sorry.
b-elliott
Post by b-elliott »
I like this idea. I'd buy one if I liked they shape of the knife otherwise. I believe Joe Pardue makes something like this called the toggle folder.
Joe Pardue Toggle Folders
Brent Elliott :spyder:
Michael Cook
Post by Michael Cook »
:spyder: So a typical straight razor would be considered a friction folder. I must be missing the appeal. :confused: :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
arzh
Post by arzh »
it will be a very cool concept and here in europe it's a legal system in the most of countries
it was an old italian system so it will be cool in the ethnics series
one more :spyder: dream
thanks
arzh
Richard IV
Post by Richard IV »
The main purpose of this is to be legal in most european countries. That would be nice. We all carry illegal stuff here (even the Ladybug...), and we are subject to lose our Spydies if searched by a suspicious cop...
BTW, don't forget the corkscrew, this time!
R.IV
arzh
Post by arzh »
R.IV you will bring your corkscrew for the sicac
i will bring a good bordeaux or croze hermitage
